i'm using catalyst drives 7.10, computer specs in my profile
my ps2 is connected via composite VIVO to my x1900xt
i've used various programs such as MPC, Dscaler, VirtualDub and VLC to play, but all have horrible quality. The image is very jagged, out of focus, blurry, the text is unreadable.
MPC and Virtual dub gives me shit for resolution, 720x240. Does this have to do with the image being interlaced? Does it cut the resolution in half because only half the lines are drawn or something? I can have the image fill a 4:3 window and it fixes the window size, but the quality remains horrible.
Here are some screenshots, i can't play like this!
media player classic:
http://i10.tinypic.com/89sh4rr.jpg
dscaler, also won't allow me to change the resolution because the option is grayed out, and i'm using overlay not D3D:
http://i17.tinypic.com/6jvpifl.png
http://i13.tinypic.com/7ygbh53.png
it looks pretty much the same in all the other programs, IE blurry, jittery, shitty, shitty shitty!
also, i can't install ATI's MMC because after catalyst 6.x only first party video cards let you install the program.
I had that same problem with the resolution being 720x240 by default. You should be able to change that in virtual dub under video > capture pin.
Try virtualvcr,lot better than virtualdub for setting resolution.
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 05:48 -
Is my ATI TV Wonder 650 damaged, or did I just pick a bad test tape?
By Mini-Me in forum Capturing and VCRReplies: 17Last Post: 7th Dec 2010, 00:54 -
Getting bad quality with AutoGK
By alc112 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Aug 2010, 09:37 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
resolved: Need source for software for capture through ATI VIVO card
By palouse in forum Capturing and VCRReplies: 5Last Post: 7th Jun 2007, 11:56
