can some one help i have tied to capture with a few diffrent progs
but the quality always seems to be rubbish .
i have an athlon 1.6 xp 512 ddr and i am trying to capture from an ati tv wonder card . can someone offer any help on how best to do it and what s the best proggy to use
cheers
Can't really help directly, but from what I've read, getting the correct drivers in place is a real work of art. Search the forum for ati and you'll find a bunch of info. Also, it would help if you included your type of ati card. Good luck
ps - I came across this link on another thread
http://www.vcdhelp.com/ATI_AIW_Guide.htm -
I think Virtual dub is the best around. I'm venturing a guess you European so capture at 352x576 using a 2:1 cubic reduction (under video menu) with no video compression or Huffy if you have to. This will get you a 352x288 avi file that you can feed into TMPGenc to make very good VCDs (just barely less than 200 lines of resolution).
Capturing Help
By Kyoji24 in forum Capturing and VCRReplies: 4Last Post: 23rd Apr 2010, 07:37 -
What are you capturing?
By ryangarfield in forum Capturing and VCRReplies: 10Last Post: 20th Apr 2010, 15:16 -
Capturing help.
By fuseek in forum Capturing and VCRReplies: 0Last Post: 6th May 2008, 10:49 -
Capturing in HD
By The Sumerian in forum Capturing and VCRReplies: 1Last Post: 7th Jun 2007, 12:40
