Results 1 to 12 of 12
  1. My writer has recently started producing coaster with weird burntracks. The supplied picture shows two discs burned with dvddecrypter:
    I burned an image that was 4,7 gigs, so the discs should be full.
    The one on the left was supposedly "successful" without verification afterwards, the one on the right was also "succesful" but failed "verify" for obvious reasons. I also tried to burn the image with Nero, which produced a disc quite similar to the left one.
    I made sure to save the Nero log:
    Windows XP 5.1
    IA32
    WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 2004-07-23 20:11:36
    ahead WinASPI: File 'C:\Program\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004-11-02 11:54:32
    NT-SPTI used
    Nero Version: 6.6.1.4
    Internal Version: 6, 6, 1, 4d
    Recorder: <IOMEGA DVDRW4216INP-A> Version: 1.A0 - HA 1 TA 1 - 6.6.1.4
    Adapter driver: <IDE> HA 1
    Drive buffer : 2048kB
    Bus Type : default (0) -> ATAPI, detected: ?
    CD-ROM: <VR3501T PXJ966G >Version: 1.0 - HA 1 TA 2 - 6.6.1.4
    Adapter driver: <SCSI> HA 1
    === Scsi-Device-Map ===
    DiskPeripheral : Maxtor 4D040H2 atapi Port 0 ID 0 DMA: On
    CdRomPeripheral : MATSHITA CD-ROM CR-594 atapi Port 1 ID 0 DMA: Off
    CdRomPeripheral : IOMEGA DVDRW4216INP-A atapi Port 1 ID 1 DMA: Off
    DiskPeripheral : ST3250623NS 5.01 viamraid Port 2 ID 0 DMA: Off
    CdRomPeripheral : VR3501T PXJ966G 1.0 azkegu22 Port 3 ID 0 DMA: Off
    === CDRom-Device-Map ===
    VR3501T PXJ966G F: CDRom2
    AutoRun : 1
    Excluded drive IDs:
    WriteBufferSize: 83886080 (0) Byte
    ShowDrvBufStat : 0
    BUFE : 0
    Physical memory : 1022MB (1047024kB)
    Free physical memory: 284MB (291632kB)
    Memory in use : 72 %
    Uncached PFiles: 0x0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    22.11.2007
    Burn DVD Image
    06:16:25 #1 Text 0 File ThreadedTransfer.cpp, Line 531
    ReadBuffer-Pipe got 81920KB of Memory
    06:16:25 #2 Text 0 File Reader.cpp, Line 124
    Reader running
    06:16:25 #3 Text 0 File Writer.cpp, Line 122
    Writer IOMEGA DVDRW4216INP-A running
    06:16:25 #4 Text 0 File Burncd.cpp, Line 3305
    Turn on Disc-At-Once, using DVD media
    06:16:26 #5 Text 0 File DlgWaitCD.cpp, Line 281
    Last possible write address on media: 2295103 (510:01.28, 4482MB)
    Last address to be written: 2177753 (483:56.53, 4253MB)
    06:16:26 #6 Text 0 File DlgWaitCD.cpp, Line 293
    Write in overburning mode: NO (enabled: CD)
    06:16:26 #7 Text 0 File DlgWaitCD.cpp, Line 2612
    Recorder: IOMEGA DVDRW4216INP-A, Media type: DVD+R
    06:16:26 #8 Text 0 File DlgWaitCD.cpp, Line 459
    >>> Protocol of DlgWaitCD activities: <<<
    06:16:26 #9 Text 0 File ThreadedTransferInterface.cpp, Line 847
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, ISO 9660)
    2 indices, index0 (150) not provided
    original disc pos #0 + 2177754 (2177754) = #2177754/483:56.54
    not relocatable, disc pos for caching/writing not required/not required, no patch infos
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2177754 blocks [IOMEGA DVDRW4216INP-A]
    06:16:26 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1059
    Prepare recorder [IOMEGA DVDRW4216INP-A] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 1:
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4460040192, ISRC ""
    DAO layout:
    __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
    0 | lead-in | 0 | 0x41 | 0x00
    0 | 1 | 0 | 0x41 | 0x00
    0 | 1 | 1 | 0x41 | 0x00
    2177754 | lead-out | 1 | 0x41 | 0x00
    06:16:26 #11 Text 0 File SCSIPassThrough.cpp, Line 38
    SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
    06:16:26 #12 Text 0 File SCSIPassThrough.cpp, Line 83
    SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
    06:16:26 #13 Phase 24 File dlgbrnst.cpp, Line 1685
    Caching of files started
    06:16:26 #14 Text 0 File Burncd.cpp, Line 4145
    Cache writing successful.
    06:16:26 #15 Phase 25 File dlgbrnst.cpp, Line 1685
    Caching of files completed
    06:16:26 #16 Phase 36 File dlgbrnst.cpp, Line 1685
    Burn process started at 2.4x (3 324 KB/s)
    06:16:26 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2685
    Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
    06:16:26 #18 SPTI -1066 File SCSIPassThrough.cpp, Line 289
    E: CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1066)
    Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
    Sense Code: 0x24
    Sense Qual: 0x00
    CDB Data: 0xAD 00 00 00 00 00 00 00 08 04 00 00
    Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24 00 00 C0 00 07
    Buffer x0a410600: Len x804
    06:16:26 #19 Text 0 File DVDPlusRW.cpp, Line 666
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    06:38:31 #20 Text 0 File WriterStatus.cpp, Line 116
    <IOMEGA DVDRW4216INP-A > start writing Lead-Out at LBA 2177754 (213ADAh), lenght 0 blocks
    06:38:31 #21 Text 0 File ThreadedTransfer.cpp, Line 228
    all writers idle, stopping conversion
    06:40:08 #22 SPTI -600 File SCSIPassThrough.cpp, Line 289
    E: CdRom1: SCSIStatus(x00) WinError(55) NeroError(-600)
    Sense Key: 0x00 (KEY_NO_SENSE)
    Sense Code: 0x00
    Sense Qual: 0x00
    CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00
    Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00
    Buffer x02e75400: Len x20
    06:40:08 #23 CDR -600 File ThreadedTransferInterface.cpp, Line 1937
    Device not available
    E: IOMEGA DVDRW4216INP-A
    06:40:08 #24 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1937
    Could not perform end of Disc-at-once
    06:40:08 #25 SPTI -500 File SCSIPassThrough.cpp, Line 289
    E: CdRom1: SCSIStatus(x00) WinError(2) NeroError(-500)
    Sense Code: 0x00
    Sense Qual: 0x00
    CDB Data: 0x35 02 00 00 00 00 00 00 00 00 00 00
    06:40:08 #26 SPTI -500 File SCSIPassThrough.cpp, Line 289
    Sense Code: 0x00
    Sense Qual: 0x00
    CDB Data: 0x5B 01 05 00 00 00 00 00 00 00 00 00
    06:40:08 #27 Phase 127 File dlgbrnst.cpp, Line 1685
    Generating DVD high compatibility borders
    06:40:08 #28 CDR -500 File WriterStatus.cpp, Line 167
    SCSI command aborted
    06:40:08 #29 TRANSFER -24 File WriterStatus.cpp, Line 167
    06:40:08 #30 SPTI -500 File SCSIPassThrough.cpp, Line 289
    Sense Code: 0x00
    Sense Qual: 0x00
    CDB Data: 0x5A 00 05 00 00 00 00 00 48 00
    Buffer x02e75200: Len x48
    06:40:08 #31 SPTI -500 File SCSIPassThrough.cpp, Line 289
    Sense Code: 0x00
    Sense Qual: 0x00
    06:40:09 #32 CDR -500 File WriterStatus.cpp, Line 172
    06:40:09 #33 TRANSFER -39 File WriterStatus.cpp, Line 172
    Could not perform EndSession
    06:40:09 #34 Phase 38 File dlgbrnst.cpp, Line 1685
    Burn process failed at 2.4x (3 324 KB/s)
    06:40:09 #35 SPTI -500 File SCSIPassThrough.cpp, Line 289
    CdRom1: SCSIStatus(x00) WinError(5) NeroError(-500)
    Sense Code: 0x00
    Sense Qual: 0x00
    CDB Data: 0x1E 00 00 00 00 00 00 00 00 00 00 00
    Existing drivers:
    File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 2006-05-19 22:16:24
    File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 2007-03-08 00:51:00 (Prassi/Veritas driver for win 2K)
    File 'Drivers\scsiport.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=96256 bytes, created 2004-08-03 21:59:42 (Adapter driver for src)
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
    After Nero failed during Lead-out, I had to forcefully excise the disc with a paperclip.
    So, is the drive pooched? I have easily burned 500+ discs, and I recently learned burner have a limited lifespan.
    Will I need to get a new one?
    Tl;DR: Iz me burna scrood?
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    According to that log you posted, DMA is off on your IOMEGA DVDRW. You'll need to enable it. Here's a link on how to enable DMA mode.
    http://www.cdrlabs.com/forum/viewtopic.php?t=7625
    If you have problems in enabling DMA mode look at this link below:
    http://www.cdrlabs.com/forum/viewtopic.php?t=6645
    If you are able to enable DMA mode but the burns still fail (lead out) then try burning with IMGBURN instead of NERO. If using IMGBURN fails as well then it's time for you to buy a new dvd burner.
  3. I know it says "DMA: off", but even if it is, I have burned dozens of good discs with it that way, so I highly doubt that's the problem.
    Edit: After having checked DMA settings after a reboot, all settings seem to be in order, all IDE channels running on UDMA, so the settings don't seem to be the problem.
    Gonna try a last burn with ImgBurn to see if the software is the issue, which I doubt it is.
  4. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    then you must have been burning your dvd discs very slow in PIO mode. since DMA mode is now enabled you should be burning dvd discs fine unless you get another failure then it's your laser that's dying which means time to buy a new dvd burner which is so cheap these days.
  5. Originally Posted by budz
    No, what I was saying was that the DMA settings were always in order and DMA was always on.
    I do burn slowly at 2,4x because for some reason my burner won't go faster, it would go to 4x when it was new but that ended after a while, but I think even 2,4x is was too fast for it to be PIO.
    The ImgBurn session is done soon, and I expect the same results as with Nero and DVDDecrypter.
  6. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    from that log you posted DMA was OFF therefore it was not in order. you say it would burn 4x speed but that ended because your dvd burner was PIO mode which will cause burn speed to drop to a slow speed. when a dvd burner is in DMA mode you will achieve the burn speeds that the burner is suppose to be at. as i said if you're able to burn a disc okay with IMGBURN then your drive is fine. by the way what brand of dvd media are you using?
  7. OK, so I burned 4 discs alternating between ImgBurn and DVDDecrypter, everyone apparently successful, completing both burning and verification.
    Burned a fifth disc with Nero, and this one failed a minute or two into the burn.
    Saved the log:
    Windows XP 5.1
    IA32
    NT-SPTI used
    CdRomPeripheral : MATSHITA CD-ROM CR-594 atapi Port 1 ID 0 DMA: On
    CdRomPeripheral : IOMEGA DVDRW4216INP-A atapi Port 1 ID 1 DMA: On
    CdRomPeripheral : VR3501T PXJ966G 1.0 at74tgmh Port 3 ID 0 DMA: Off
    MATSHITA CD-ROM CR-594 D: CDRom0
    IOMEGA DVDRW4216INP-A E: CDRom1
    AutoRun : 1
    Excluded drive IDs:
    ShowDrvBufStat : 0
    BUFE : 0
    Free physical memory: 312MB (319496kB)
    Memory in use : 69 %
    Use Inquiry : 1
    22.11.2007
    Burn DVD Image
    22:01:43 #1 Text 0 File ThreadedTransfer.cpp, Line 531
    ReadBuffer-Pipe got 262144KB of Memory
    22:01:43 #2 Text 0 File Reader.cpp, Line 124
    Reader running
    22:01:43 #3 Text 0 File Writer.cpp, Line 122
    22:01:43 #4 Text 0 File Burncd.cpp, Line 3305
    22:02:16 #5 Text 0 File DlgWaitCD.cpp, Line 281
    Last address to be written: 2286021 (508:00.21, 4464MB)
    22:02:16 #6 Text 0 File DlgWaitCD.cpp, Line 293
    22:02:16 #7 Text 0 File DlgWaitCD.cpp, Line 2612
    22:02:16 #8 Text 0 File DlgWaitCD.cpp, Line 459
    Insert empty disc to write to.
    (Medium in drive: Unknown. Medium required by compilation: DVD+R/RW.)
    22:02:16 #9 Text 0 File ThreadedTransferInterface.cpp, Line 847
    original disc pos #0 + 2286022 (2286022) = #2286022/508:0.22
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286022 blocks [IOMEGA DVDRW4216INP-A]
    22:02:16 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1059
    DAO infos:
    MCN: ""
    Tracks 1 to 1:
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681773056, ISRC ""
    DAO layout:
    2286022 | lead-out | 1 | 0x41 | 0x00
    22:02:16 #11 Text 0 File SCSIPassThrough.cpp, Line 38
    22:02:16 #12 Text 0 File SCSIPassThrough.cpp, Line 83
    22:02:16 #13 Phase 24 File dlgbrnst.cpp, Line 1685
    22:02:16 #14 Text 0 File Burncd.cpp, Line 4145
    22:02:16 #15 Phase 25 File dlgbrnst.cpp, Line 1685
    22:02:16 #16 Phase 36 File dlgbrnst.cpp, Line 1685
    22:02:17 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2685
    22:02:17 #18 SPTI -1066 File SCSIPassThrough.cpp, Line 289
    Sense Code: 0x24
    Sense Qual: 0x00
    Buffer x04420600: Len x804
    22:02:17 #19 Text 0 File DVDPlusRW.cpp, Line 666
    22:04:39 #20 SPTI -1135 File SCSIPassThrough.cpp, Line 289
    E: CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1135)
    Sense Key: 0x03 (KEY_MEDIUM_ERROR)
    Sense Code: 0x0C
    Sense Qual: 0x00
    CDB Data: 0x2A 00 00 02 E1 80 00 00 20 00 00 00
    Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 0C
    Buffer x04d90000: Len x10000
    0x00 00 01 BA 44 2B 9D 5C CC C7 01 89 C3 F8 00 00
    0x01 E0 07 EC 81 00 00 18 0C 0C 4E 53 E5 00 46 D0
    0x6E 60 0A 32 73 85 9B A0 1E 97 83 DC 6B 71 F6 7A
    22:04:39 #21 CDR -1135 File Writer.cpp, Line 311
    Write error
    22:04:39 #22 Text 0 File ThreadedTransfer.cpp, Line 228
    22:04:39 #23 Text 0 File ThreadedTransfer.cpp, Line 222
    conversion idle, stopping reader
    22:04:39 #24 SPTI -1135 File SCSIPassThrough.cpp, Line 289
    Sense Code: 0x0C
    Sense Qual: 0x00
    CDB Data: 0x5B 01 01 00 00 01 00 00 00 00 00 00
    22:04:39 #25 SPTI -1176 File SCSIPassThrough.cpp, Line 289
    E: CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1176)
    Sense Code: 0x72
    Sense Qual: 0x03
    Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 72 03
    22:04:39 #26 Phase 127 File dlgbrnst.cpp, Line 1685
    22:04:39 #27 Phase 129 File dlgbrnst.cpp, Line 1685
    Generating DVD borders completed successfully
    22:04:39 #28 Phase 38 File dlgbrnst.cpp, Line 1685
    Existing drivers:
    Registry Keys:
    Note how the DMA says "on".
    I'm fairly certain the drive is balancing precariously on its last arthritic leg, so I'm gonna get a new one.
  8. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    what brand of dvd media are you using? according to your log it says "UNKNOWN" media. if you're using some cheap dvd media it could be why your burner is failing to burn the disc. you could buy some VERBATIM dvd media and test it w/your drive. if fails to burn as well only then would I say buy a new dvd burner.
  9. Originally Posted by budz
    Hehe, Verbatim, Like the ones I've been using? http://www.sweburn.com/product_info.php?cPath=23&products_id=77&language=en
    It got through the first 45 or so of the 50-stack before producing errors, then producing a couple more errors with the first discs of a new 50-stack, but it also successfully burned a couple of discs, complete with verify procedure and all.
    It's so delightfully random that I can really only chalk it up to hardware failure.
  10. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    good then buy a new dvd burner.
  11. I just installed and burned my first disc with my new burner, an 18-speed Samsung.
    It burned it's first disc at 12x and it passed verification with flying colors.
  12. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Good to hear that!
