We have made a DVD in encore that is simply one piece of video that endlessly loops from the end back to the begining. The loop works fine however usually just after the loop point there is a freeze for a few frames then the video plays fine. The loop point is a pure white frame. We can get rid of the glitch by making the white longer so you don't see the glitch.
So my question is how good should the loop function be and is its performance player dependant. Obviously at the end of the video clip the player has to jump instantly to somewhere else on the disc so there is always going to be a delay but is this a random thing depending on player? Would you expect the join to be perfect???
NIge
Can't be perfect as you've noted the player has to kick back to the start. Some players will react better than others. Oppo claims to have a buffer to help eliminate the lag you'll sometimes notice with DL discs as they switch layers.Obviously at the end of the video clip the player has to jump instantly to somewhere else on the disc so there is always going to be a delay but is this a random thing depending on player? Would you expect the join to be perfect???
Basic Issue - want to make video loop using DVD Studio Pro
By Donny Rowles in forum Authoring (DVD)Replies: 2Last Post: 19th Sep 2011, 13:56 -
How to loop avi file
By Nagaraj in forum Newbie / General discussionsReplies: 0Last Post: 12th Mar 2011, 07:17 -
playing a file in a loop
By devdev in forum EditingReplies: 1Last Post: 27th Apr 2010, 13:20 -
i'm out of the loop..could someone update me?
By 91rtstealth in forum MacReplies: 6Last Post: 6th Nov 2008, 17:48 -
C# loop issue
By Darth Paris in forum ComputerReplies: 7Last Post: 23rd Oct 2007, 18:36
