  1. Member zoobie's Avatar
    Feb 2005
    Florida
    Anyone using this supposedly great encoder?
    Looks like it runs a little script and is several years old.
    Can't get it to work with type 1 DV-AVI
    Settings?
    Thx
  2. Member Soopafresh's Avatar
    Jan 2004
    You need to feed it an Avisynth script
    DVfile.AVS
    DirectShowSource("yourDVfile.avi")
    FixBrokenChromaUpsampling() #Perhaps not needed
    BicubicResize(640,480) #To maintain Aspect Ratio
    #Any Additional Filters
    Start with installing the latest 2.58 Avisynth
    Save the script above as DVfile.AVS
    Feed it into WMnicEnc
    AutoMKV should work as well, and you won't have to manually create a script.
  3. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    I like WMVMuxer. I use it all the time with my HDV when I want to encode it for someone with an Xbox. Very good quality.
  4. Member zoobie's Avatar
    Feb 2005
    Florida
    nice little aps
    thx
