Is there anyway to remove a subtitle stream from a MKV file without having to extract everything out of it and put it back together with out the subtitles?
Why would you want to do this? With the MKV container, the subtitle should be optional - that is, you don't HAVE to watch it, so there should be no need to mess with it. If the subtitle is burned into the movie, you won't be able to remove it.
There are some MKV demux tools that might help if the subtitle is actually a separate stream and not burned in, but again you shouldn't have to do this.
How to Remove subtitle track from .MKV ?
By Clifurd in forum SubtitleReplies: 2Last Post: 13th May 2011, 23:32 -
Best way to remove subtitle stream?
By rmdeboer82 in forum DVD RippingReplies: 1Last Post: 7th Jul 2010, 05:15 -
Convert subtitle of .idx/.sub to .sup for AVCHD, Remove embedded subtitle.
By wisitch in forum SubtitleReplies: 2Last Post: 18th Jun 2010, 11:25 -
Conver MKV with ENG audio/subtitle to AVCHD or Blu-ray with subtitle help?
By teaberry in forum Video ConversionReplies: 2Last Post: 3rd May 2010, 17:03 -
Remove subtitle stream from MP4
By Digiface in forum DVD RippingReplies: 1Last Post: 21st Jan 2008, 09:41
