Dear friends,
I am a newbie in this forum. So my question might sound a bit silly. I have .VOB files from two different DVDs.
For example...the first one with VTS_01_1.VOB, VTS_01_2.VOB, VTS_01_3.VOB and the second one has
.VOB files as VTS_02_1.VOB, VTS_02_2.VOB, VTS_02_3.VOB. Now I wanna bring the both into a single DVD having
a simple menu (no chapters yet!). I have DVDStyler, DVDShrink, DVDDecrypter. Please tell me how I can
do so.
Bye.
Use TDA / TMPGENC DVD Author. The programs you list won't work.
Import VOBs in order desired, then author as menu-less disc. Done.Want my help? Ask here! (not via PM!)
LS's suggestion is probably easiest, but if you need a freeware solution, GFD can import VOB files. It is not as simple to use as the two solutions he suggested, but it can do what you want.
[Edit]...Well maybe not. I should have looked further. It will import VOB's but if you have a VOB set, and you do, it wants them joined into one VOB before you import them. So, that would need to be done first, using another program.
Does a simple AVCHD authoring program exist like DVD programs?
By Killer3737 in forum Authoring (Blu-ray)Replies: 4Last Post: 29th Sep 2011, 11:16 -
Simple DVD Authoring
By DeathStalker77 in forum Authoring (DVD)Replies: 22Last Post: 26th May 2010, 01:40 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
Simple VOB authoring solutions
By kippard in forum Authoring (DVD)Replies: 5Last Post: 22nd Jul 2008, 08:27 -
Again on Simple DVD authoring
By asadfx in forum Newbie / General discussionsReplies: 1Last Post: 22nd Nov 2007, 07:22
. I have
