Here is the newbie questions....
1st
Is there a program or player that will play multiple formats?
I have a few favorite items that I like to show people.
1 - is a .mov format and 1 - is .avi format.
I would like to play these both at the same time instead of having to play each seperately.
If I need to convert then that is not a problem just will have to learn.![]()
2nd
Is there a player that will play 3 seperate files of the same format.
load 3 avi file and run back to back.
If this program has drag and drop features it would be perfect.
You can start up multiple instances of some players. Like MPC, KMPlayer, VLC, mplayer2 (comes with WMP). You may have to enable multiple instances in the players' options. Of course, you have to sync the players yourself when doing this.
AviSynth has the ability to open multiple sources and stack them vertically and/or horizontally. You can then use any player to display the results. -
Mass conversion to multiple file formats
By Haopengyou in forum AudioReplies: 8Last Post: 11th Aug 2011, 02:35 -
Deinterlace first or multiple times? Encoding source to multiple formats.
By greyfalcon in forum Video ConversionReplies: 1Last Post: 12th Apr 2011, 04:39 -
:?: Authoring software recomendation/encodes multiple formats
By pgwerner in forum MacReplies: 3Last Post: 29th Dec 2008, 14:13 -
Converting multiple formats to WMV
By StrangeSolutions in forum Video ConversionReplies: 5Last Post: 9th Dec 2008, 19:43 -
editing with multiple formats
By abadifilms in forum MacReplies: 1Last Post: 15th Sep 2008, 13:59
