How do you convert a DivX file w/4 subtitles to AVI so you can have 4 external subtitle files for uploading to make it easier (wider selection of software & stand alone players) for the downloader to view, convert or burn with their choice of subtitle? Movie only plays with DivX player and subtitle choice. If file extension is renamed divx to avi it will play in more players but no subtitles.
This is the specific file info just in case it is needed.
GSpot info -----lines with no information have been removed to conserve space
--- Container Information ---
Base Type (e.g "AVI"): AVI(.AVI)
Subtype (e.g "OpenDML"): OpenDML (AVI v2.0),
Interleave (in ms): 40
Preload (in ms): 504
Audio alignment("split across interleaves"): Split
Number of Audio Streams: 1
--- Video Information ---
Video Codec Type(e.g. "DIV3"): DX50
Video Codec Name(e.g. "DivX 3, Low-Motion"): DivX 6.2.5
Video Codec Status(e.g. "Codec Is Installed"): Codec(s) are Installed
Duration (hh:mms): 2:14:18
Frame Count: 201426
Frame Width (pixels): 720
Frame Height (pixels): 528
Storage Aspect Ratio("SAR")" 1.364
Pixel Aspect Ratio ("PAR"): 1.000
Display Aspect Ratio ("DAR"): 1.364
Frames Per Second: 25.000
Pics Per Second: 25.000
Video Bitrate (kbps): 899
MPEG-4 ("MPEG-4" or ""): MPEG-4
B-VOP ("B-VOP" or ""): B-VOP
Quality Factor (bits/pixel)/frame: 0.095"
--- Audio Information ---
Audio Codec (e.g. "AC3"): 0x0055 MPEG-1 Layer 3
Audio Codec Status (e.g. "Codec Is Installed"): Codec(s) are Installed
Audio Sample Rate (Hz): 48000
Audio Bitrate(kbps): 80
Audio Bitrate Type ("CBR" or "VBR"): CBR
Audio Channel Count (e.g. "2" for stereo): 2
additional info not generated
Proposed Codec Solutions & Test
GSpot
1 status not rendered yet use 2
2 (condensed) AVI chunk window pops up (5 times) This avi file was not prepared for sequential reading alt 'Avi Splitter will let default handle complete re interleaving is strongly recommended before burning onto a slow media like cd-rom
failed to connect output pin to input pin 5 different address for each failed error 0x80040207 unknown
video render ok use 3 to play
3. movie plays no volume
MS A/V
1. AVI chunk window pops up 1 time This avi file was not prepared for sequential reading alt 'Avi Splitter will let default handle
render ok use following combinations to play
DSH Friendly Name ffdshow MPEG-4 Video Decoder
DSH Friendly Name MPEG Layer-3 Decoder
2. movie plays with sound
Closed Thread
If it's xsubs in a divx I haven't seen any tool for that yet, see https://forum.videohelp.com/topic272324.html or http://forum.doom9.org/showthread.php?t=110269
PLEASE don't cross post. Continue in https://forum.videohelp.com/topic340781.html
Convert DivX file with subs
By marioval in forum Video ConversionReplies: 6Last Post: 17th Oct 2010, 17:23 -
Using Mkv2vob to convert mkv to avi with subs.
By spunge85 in forum Video ConversionReplies: 2Last Post: 11th Jan 2010, 15:21 -
How to convert MKV with soft subs to AVI using DVDFab 6.x
By Shilar in forum User guidesReplies: 0Last Post: 28th Aug 2009, 10:15 -
I have downloaded file clips in .divx how can I convert to .avi?
By Ricksasha in forum Video ConversionReplies: 8Last Post: 13th Nov 2007, 14:36 -
I can't add subs to a DivX file I have for some reason...
By darkzero297 in forum SubtitleReplies: 1Last Post: 4th Jul 2007, 19:41
s): 2:14:18
