I have been trying to find a solution for a while, other than formatting my computer. I can't get x264 or h264 to play in WMP. I have no problems getting it to play in VLC or Media Player Classic. I am running vista and Windows Media Player 11. I want to get it to play in WMP so that I can use Media Portal or MCE. Instead I get an error every time I try to start the file. I have reinstalled Ffdshow and continue to get the error. When i play the video in MPC the ffdshow icon shows in the tray and everything works fine, but it wont work at all in WMP. Can someone please help.
What is the error msg? I have tried WMP 11 in Windows Vista with latest ffdshow and haali media splitter and mkv/mp4 with h264 worked fine.
First it says windows has encountered a problem while trying to play this file. The box then says close or Web help. When I click on web help I get this error: C00D11B1
Here is the link: http://www.microsoft.com/windows/windowsmedia/player/webhelp/default.aspx?&mpver=11.0....nalid=80004005
It says it is something with the sound driver... but everything else works fine. I can't figure this out.... Thanks for trying to help. -
Try dropping the file into Gspot 2.70 and see what it says. If you are missing a codec, audio or video, it should tell you which one. You can also 'render' the file and it will show what codecs and processes it uses to play it. Audio formats can be varied and you may not have the proper codec for it.
Alternatively, you might try VLC player as it should play H.264 without adding codecs. It's a good test to see if you have a codec problem. -
I did use gspot and a bunch others and none were able to tell me what was missing. I settled on reformatting the computer. Now it works fine.
Except... all of a sudden the white areas on the videos are all messed up.. there are black swirlys all over it. It is primarily wherever it is bright on the screen. It doesn't happen in VLC player. Can't figure out what happened. Can't figure out how to look up help. When I type in google.. no clue what to look for... Any ideas?
Sound and video do not sync up when I convert avi to h.264 x 264.
By toddlava1 in forum ffmpegX general discussionReplies: 1Last Post: 8th Mar 2012, 03:15 -
Empty audio files when converting MPEG2 with h.264 mencoder or h.264 x264
By doctormelodious in forum ffmpegX general discussionReplies: 3Last Post: 4th Jul 2010, 09:12 -
Philips 5992 DVDP?? Upgraded Firmware but H.264 doesn't work?
By sandman423 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Dec 2008, 10:09 -
Converting .avi (Xvid) to .mp4 or .mkv (H.264 or x.264) w/ subs
By Tensai in forum Video ConversionReplies: 4Last Post: 18th Jul 2007, 10:25 -
DVB MPEG2 544X480 convert to H.264 - Any clean work flows?
By Raycaster in forum Video ConversionReplies: 0Last Post: 18th Jul 2007, 09:57
