    Sep 2007
    I've been doing some reading, lurking, and searching... can't seem to find any guide on how to do this, or if it's possible.
    I understand that PSP needs a specific number of pixels (or less), and that (possibly) it want's some non-standard info in the header, but I'm not really sure about the rest...
    TIA for any help
    e
  2. Member classfour's Avatar
    The Heartland, United States
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
  3. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    How-To's for ffmpegX:
    PSP
    iPod
    Sep 2007
    Thanks for the replies -- but to be sure: My goal is to encode a single video that will play on both a PSP and an iPhone (without having to encode the video twice, once for each device), not to how to make a fle for a PSP or an iPhone.
    Does the PSP not need the non-standard header stuff any more? I tried to play a file that was made for the PSP on my iPhone, and it wouldn't play (which lead to my question).
    Thanks Again
    e
  5. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    If they both need special metadata excluding the other's, which I think is the case, then it may not be possible to create a file playing on both. I suppose a video converter software developer could confirm or deny that.
