Is there a DVD player that will play .avi files without any conversion? I'd like to load a DVD with several short (3 min to 20 minute) clips. And I need a new DVD player anyway, so what do I need to get?![]()
Results 1 to 12 of 12
_____________________
Micallen -
Most new dvd players supports avi in divx and xvid format.
Will it work if I burn it to CD's and well as DVD's ?
Micallen -
Yes. (Even if some very few players can't grasp the concept of a data DVD, and only play AVI from CD.) And while you're out shopping, get a player with USB. That way you don't even have to burn to disk to watch.
/Mats -
Sweet. I've been poking around in here and it looks like the Philips DVP 5982 might be a good one.
Micallen -
And keep in mind, that any player you choose likely won't play ALL of your avi files.
Google is your Friend -
KK, what if the .avi files are all from the same source (my digital camera)? If one plays fine, shouldn't they all play fine?
Micallen -
Most likely, yes. But all AVI players I've heard of plays DivX/XviD AVI (the ones you create with AutoGK and the like) - and I've never heard of a camera recording to avi of that flavor.
/Mats -
a couple of years ago i had a DVD player that played all my avi files and then it broke down. i got a new one but my avi's wont play in it. i am going to buy a new DVD player tommorow. what should i be looking for in the product details if i want one to play the avi files? if it says it will play DVD/DVD-R/DVD-RW/VCD/CD/CD-R/CD-RW discs, doe sthat mean it will play anything on those types of discs?
No, it just means it will play those type of discs, nothing to do with the content on them. Most any DVD player will play MPEG-2 and MPEG-1 formats. Some will play MP3 audio and JPEG photos, Then some will play Divx/Xvid files that are compatible, and most all of the above. This thread covers some of the compatible features for Divx/Xvid playback: https://forum.videohelp.com/topic340897.html#1778263
You can also sort through our DVD Player listing and choose what formats you want for playback. Divx/Xvid playback is getting fairly common, so there are a lot of them out there. The Phillips players are economical and fairly common. OPPO is one of the better quality players.
You can make 'standard' compatible Divx/Xvid files with programs like AutoGK or similar. Or you can run your non-playing files through other programs to 'fix' the problems like AVI ReComp. -
what feature should i look for if i want the player to play avi files on blank dvd-r discs?
If you get a "brand" player, look for DivX or DivX Ultra certificated players. "House brand" / no-name players may, but are rarely certified.
/Mats
why will some avi files play in my dvd player while others will not?
By panman36 in forum Newbie / General discussionsReplies: 6Last Post: 8th Nov 2010, 11:58 -
avi files can only play up to 40 minutes in DVD player, why?
By ericdunn in forum Newbie / General discussionsReplies: 8Last Post: 7th Apr 2010, 09:37 -
Help. What program to use to make avi files play on dvd player?
By xxxThiefxxx in forum Newbie / General discussionsReplies: 13Last Post: 30th Mar 2010, 18:09 -
Would this DVD player play AVI files burnt onto a blank DVD/CD?
By jane2 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 20th Apr 2008, 20:38 -
Cannot play Avi files converted to DVD on my DVD player.
By callmejr2 in forum Newbie / General discussionsReplies: 3Last Post: 9th May 2007, 11:19
