Hi,
Hope someone can help me out on this. I have two questions:
1. Tmpgenc dvd author is very slow:
I'm trying out tmpgenc dvd author 3 to convert .avi files to dvd. I put four episodes (4 .avi files, each about an hour long, mp3 audio) into the dvd, so there was some compression needed to fit it onto a dvdr. It took about 11 hours to convert this - I set the motion detection on high though (I wasn't really sure what this was for) and the video encoding on 2-pass. I also had audio background and motion thumbnails for the track menus, which I know adds time to the process. But should it really take this long??
(Computer specs: P4 3.4GHz, 2GB RAM)
Please let me know if I need to include any other info!
2. Other methods to use?
I used to use convertxtodvd and it took probably avg 3 hours to convert something like this, but it didn't provide me with the advanced menu features I'd like (motion menus, motion thumbnails, background audio, etc). I also liked nero vision, but according to everyone at this forum, the output quality isn't great (although I could only tell a bit from comparing the output using the three programs).
Methods I currently use:
1. Use Virtualdubmod to hardsub my subtitles, convert hardsubbed .avi files to dvd with tmpgenc dvd author (does this program allow you to load .srt or external subs??)
2. Same as above but convert/author with nero vision
3. Convert .avi file with .srt file to dvd using convertxtodvd
Is there a better way to convert .avi files (with subtitles) to dvd (with more advanced menu options)? I have other programs like CCE and dvdlabpro, but they're not as user-friendly and I'm still working on figure it out.
THANK YOU in advance for the help!!
	You can import srt in tmpgenc dvd author but it doesn't seem to work with all srts, see https://forum.videohelp.com/topic335908.html#1750003
 If you want faster encoding use 1-pass encoding and set the motion detection to fast. The video quality will probably not be as good as 2-pass encoding.
	TMPGEnc programs are damn slow because their creator believes
 "the slower, the better" . In the case of 2-pass encoding, the . In the case of 2-pass encoding, the
 things go even worse.
 Converting to MPEG and authoring a DVD file structure would better
 remain two completely distinct processes. In your specific case, the
 first step should be transform .avi files into hardsubbed .MPEGs by
 using Avisynth and a dedicated MPEG encoder; the second step is
 to transform those MPEGs into .IFOs, .BUPs and .VOBs.
 And yes, CCE's GUI is not good, but no, DVD-lab's GUI is not difficult
 to understand at all. User-friendly is not a synonym for carnivalish
 (I'm talking about Nero Vision Express).
 Hope this helps.
  TMPGEnc DVD Authoring Audio slowdownBy Namrepus221 in forum Authoring (DVD)Replies: 0Last Post: 11th Oct 2009, 03:25
  TMPGEnc Authoring Works v.4.0.4.24 - AuthoringBy niteghost in forum Authoring (DVD)Replies: 8Last Post: 21st Jul 2009, 22:15
  [help] TMPGENC DVD AUTHORING v3 - unable to convert to MPGBy meeya in forum Authoring (DVD)Replies: 3Last Post: 19th Dec 2008, 05:47
  Can't have more than 24 chapters on TMPGEnc DVD Authoring?By aqualung2003 in forum Authoring (DVD)Replies: 19Last Post: 5th Jan 2008, 15:41
  Authoring causes video to slow... (explained inside)By Liquid Drum Theater in forum Authoring (DVD)Replies: 13Last Post: 11th Sep 2007, 15:17
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
