This is a problem I've had for a few years now. I'm not really looking for a one-shot solution (although that'd be nice) but simply any hint as to what's going on.
I've got an old VHS home movie I'd like to capture. Viewed on a television (and I've tried this with several different TVs/VCRs) it looks fine, all the colors are correct. When captured (tried this with several different PCs, all Windows of various flavors, and several different capture cards, from different manufacturers, and several different capture programs) the colors come out very bright, and washed out. Mid to light grays in the original all become pure white; mid green becomes pure yellow, etc. The results look like this:
This was filmed in the hills in spring, the grass in the background should all be a mild green.
I've tried using the color adjustment options in my capture program/card driver. It's apparent that those adjustments only take place after whatever is brightening the picture, as they only affect the already-washed-out image. Since some of the image data has been lost by this point (due to the saturation at white), that doesn't help me at all.
The original was made on an old camcorder that recorded directly onto VHS tape. I'm working off a copy, made using a normal VCR.
Any ideas?
Well, the second generation tape could be part of the problem. If you can get your hands on the original, you'll start off in better shape.
Without know exactly what you've been working on......it's a little difficult to troubleshoot, but I had a similar problem when I first began using my PVR350 card. I made a few simple adjustments to brightness and contrast within the Hauppauge capture software and my troubles were gone.(tried this with several different PCs, all Windows of various flavors, and several different capture cards, from different manufacturers, and several different capture programs)
Are there any such adjustments available to you in your software?
It might be helpful if you outlined exactly what you have tried that didn't work. The folks around here tend to work with specifics - in that almost every combination of system/capture software/device imaginable has been tried and documented.
AvsPmod Seems Less Bright than Final Video
By VideoFanatic in forum RestorationReplies: 13Last Post: 22nd Apr 2012, 17:34 -
How to darken a very bright video? An easy task?
By jairovital in forum EditingReplies: 37Last Post: 17th Aug 2011, 10:42 -
Video looks washed out in certain players
By pfxz in forum Newbie / General discussionsReplies: 3Last Post: 7th Feb 2011, 19:06 -
Bright horizontal random lines in 8 mm Camcorder Video
By axhack in forum RestorationReplies: 4Last Post: 11th Jan 2008, 22:05 -
Video Plays Washed/too white
By carlitos287 in forum Software PlayingReplies: 4Last Post: 30th Oct 2007, 14:23
