Having trouble with dvd-rw discs. Recently when i erase the disc to record over it, my dvd recorder (Liteon) says that the disc is wrong format, yet i have been using these same dvd-rw discs for a while with no problems in my dvd recorder. When i try to open the disc on my pc, it either says that disc is not correct format, or says the file system on the disc is raw, and names the dvd drive a cd drive. Does anyone know how i can get these dvd-rw discs back into correct file format? Ive tried erasing and formatting the discs, but no joyany help would be greatly appreciated
Bert.
Thanks for your reply. Unfortunately imgburn erase turned out the same as before - PC wont recognise the disc, says either not compatible/wrong format, or the disc is 0.0 kb and 0.0kb available
. Anyone know of any other apps that could sort my dvd-rw's back to being usable on my dvd recorder?
p.s. I can still burn data discs in nero with these rw's, but pc optical drive and dvd recorder just wont recognise them as correct format. Thanks again for your help.
Bert. -
Reformat as full and quick several times.
WMV File with YUY2 Raw Video Format
By toreachdeepak in forum Video ConversionReplies: 3Last Post: 24th Feb 2011, 10:43 -
What format for raw encoding? VOB, AVI or MP4
By Vman94 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Oct 2010, 12:00 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 21:00 -
Burn authored VIDEO_TS as UDF or CDFS (or RAW) file system format?
By PCat in forum Authoring (DVD)Replies: 4Last Post: 26th Jan 2009, 17:33 -
Raw YUY2 to YV12 format?
By allyli2007 in forum ProgrammingReplies: 8Last Post: 2nd Jun 2007, 13:43
