I have a 1GB flash drive that I have been using to transport stuff from my PC to my Mac. When I get the stuff off of there I delete on the Mac, but when I go back to my computer it says I only have 3MB of free space even though there is nothing on there anymore, is there a way I can re-format it or something so it frees up my 1GB of space?
while plugged into the pc - right click on the flash drive icon / select format / select fast or full format - your choice. most are fat16 or fat32 again your choice.
easiest is a fast format as it just erases the pointers to the files.--
Have you tried deleting at the PC end of things? Does it do the same thing?
Presumably, the flash drive is formatted as FAT32. Perhaps it's a Mac implementation of FAT32 issue(?) -
The deleted files are probably put into a hidden folder called Trashes, it's got a . or an _ in front of it . If you enable hidden folders on the Windows side, it should show up. Deleting the folder will give you the space back. Or quick format like aedipuss said.
Yeah. You have to empty the drive's Trash on the Mac end, or delete the folder on the Windows end.
File sorting from flash drive problem - Phillips DVP5990
By Halcon in forum DVD & Blu-ray PlayersReplies: 4Last Post: 9th Apr 2012, 17:13 -
Flash Drive
By tcory in forum Newbie / General discussionsReplies: 5Last Post: 12th Dec 2010, 20:25 -
flash drive
By Pumkinhead in forum ComputerReplies: 5Last Post: 19th Nov 2010, 03:05 -
Philips DVP5990 Flash Drive Problem: Empty Card
By stormko in forum DVD & Blu-ray PlayersReplies: 7Last Post: 24th Sep 2009, 07:08 -
Time/Date Stamp - DVD, Hard Drive, and/or flash drive camcorders
By vanjh9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 2nd Feb 2009, 18:38
