Title says it all, but let me elaborate:
I use Xvid, Fairuse 2.5.
I let Fairuse pick the type of material and use about 500mb/2pass per hour.
No matter the type, I end up with a picture, that when motion starts, it appears to de-interlace - as if it's missing ever other scan line.
When I copy the avi to a dvd and play it through my Oppo DVD player, the video is BEAUTIFUL.
What am I missing?
Also dl'd video ripped from DVD's is always ok, that only difference I can see when running it through GSpot is it's 25fps not 29.
Try using divx ? install latest xvid?
Then there is no problem really, is there? What softwares are you using to play back?When I copy the avi to a dvd and play it through my Oppo DVD player, the video is BEAUTIFUL.
Detail your steps, also try alternative tools and report back.
AUTO.... AUTODETECT field interlace!
I know muchness, but if I told you everything I would have to kill you, or at least give you a harsh telling off.Corned beef is now made to a higher standard than at any time in history.
Thanks for the reply - both codecs are updated.Originally Posted by RabidDog
I let it tell me the type of DVD encoding and pick it.
I've always thought it was in Zoom Player, but it seems to play that way even in Divx's player no matter what computer - makin' me crazy - I've a HTPC with 100's of shows and I've got to burn a DVD-RW to really appreciate them.
problem with fairuse Wizard
By minkz in forum Video ConversionReplies: 4Last Post: 4th Oct 2011, 14:06 -
Fairuse Wizard problem (DVD to AVI)
By Ygramul in forum Video ConversionReplies: 3Last Post: 31st Jul 2011, 17:33 -
FairUse Wizard 2.9 muxing problem
By herbapou in forum DVD RippingReplies: 2Last Post: 17th Mar 2009, 11:21 -
problem with fairuse wizard creating project
By Wizard23 in forum ComputerReplies: 0Last Post: 11th Jan 2008, 14:30 -
video problem that is ripped from DVD with fairuse
By yunakokimama in forum DVD RippingReplies: 1Last Post: 20th Nov 2007, 21:33
