I have used my MiniDV camera to record video and audio.
Can I use Adobe Premiere Pro CS3 to only capture the audio?
I doubt it.
I use WinDV for all DV transfer. I only use Premiere to edit. I'd pull in the DV capture, then go to FILE, EXPORT and export the audio timeline.Want my help? Ask here! (not via PM!)
yes u can.when u open the capture pannel at the right top there is an option video&audio or video only or audio only
either way it takes the same time to capture it.
strange sounds in audio exported from premiere pro cs3
By codemaster in forum EditingReplies: 0Last Post: 25th Jan 2011, 19:57 -
Importing video/audio into Adobe Premiere Pro CS3
By JCW2001 in forum EditingReplies: 26Last Post: 15th Jan 2011, 21:39 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 17:27 -
Audio / Video interleave Adobe Premiere Pro CS3 problem
By mkrmec in forum EditingReplies: 5Last Post: 21st Aug 2008, 08:28 -
Importing a Photoshop CS3 image into Premiere Pro CS3
By paulinnorway in forum EditingReplies: 4Last Post: 17th Apr 2008, 08:54
