    Nov 2007
    1. Can LightSribe print in the clear center of the discs? I think their referred to as the hub, but I cant find any software with that kind of "full disc" template.
    2. Can Lightscribe print on write printable CDs...or do I need to buy an inkjet?
    USA
    1. I don't believe so, unless it's a hub-printable LightScribe disc, which I'm not sure exist.
    2. LightScribe only works on LightScribe media with a LightScribe enabled drive and with the software to make it work.
    LightScrbe website: http://www.lightscribe.com/
    And welcome to our forums.
  3. Member olyteddy's Avatar
    Dec 2005
    1. No, the hub has a 'barcode' like series of lines that are used for rotary position tracking.
  4. Mod Neophyte redwudz's Avatar
    USA
    Not quite a hub print, but you can put print close to the hub, in a circle.
