Results 1 to 9 of 9
  1. Id like to take a movie I have in AVI format and cut scenes from it, add them together then and add an mp3 for background music. whats a free and easy software to use?
  2. Windows Movie Maker.
    Supports AVIs for input, cuts/trims and can import mp3 audio.
    Limitations are output formats - DV AVI or WMV.
  3. I tried using it but it freezes up with a file this big(700MB).
  4. What format is the file and what format are you outputting to? Are you saving to an NTFS or FAT32 file drive? (If the output file exceeds 4GB it will be problematic on a FAT32 drive.)
    (I haven't had problems with multigigabyte DV AVI files)
  5. At 700MB it's a good guess that the file is a Divx or Xvid AVI. I would use VirtualDUb in Direct Stream Copy mode with Smart rendering enabled. It's not a full featured editor but it deals with that type of file well.
  6. I download it but its not very user friendly. Is there a guide on this site to help with what Im looking to do? I cant seem to find that particular one.
    Apr 2004
    Miskatonic U
    Or install the Panasonic DV Codec and save the video as DV for importing into WMM. Note : you will need at least 13 GB for each hour of DV video.
    Read my blog here.
  8. dont have that memory.
  9. Originally Posted by motleycool
    There are tons of VirtualDub guides in the "How To" section.
