I have two problems with some movies with AVI2DVD:
1. audio is about 10 seconds late than video
2. the ratio on DVD sometimes is wrong. Where can I find out which convertion I need? I was reading of "VobSub plugin setting" in the forum. Where can I find this?
Thanks for helping!
The first problem might be from the audio format. Most times MP3 VBR audio. You can check the file with Gspot 2.70 and look for the green 'VBR' light to the lower left to see if it's on. If so, you might want to extract the audio to a WAV and use that for your audio source.
The second question, are you asking about the aspect ratio? Such a 4:3 or 16:9? I believe that's set by a 'flag' while encoding.
VobSub is a DirectShow subtitle filter for subtitles.
You can just follow the highlighted link to VobSub in our 'Tools' section.
And welcome to our forums.
Try running the original AVI through this and then re-save it.
http://www.alexander-noe.com/video/amg/
Here's a shot of an AVI that gave me problems, the new saved version worked fine.
Running the new saved version through it again you'll no loger see 'bad' and the delay(ms) should now be zero.
It's also a great app for joining multiple AVI's.
Video encoding speed slower than previously
By genak in forum Newbie / General discussionsReplies: 1Last Post: 12th Oct 2010, 18:23 -
How do you get a smooth streaming video for slower connections?
By Duc851 in forum Video Streaming DownloadingReplies: 9Last Post: 2nd Sep 2009, 23:30 -
No audio in AVI2DVD w/CCE SP from MKV file?
By XyBeRz in forum Authoring (DVD)Replies: 2Last Post: 6th Feb 2009, 14:13 -
Avi2DvD stretching video
By cdaz in forum Video ConversionReplies: 4Last Post: 3rd Feb 2008, 01:12 -
TMPGEnc makes deep/slower sounding audio
By awesomer in forum Video ConversionReplies: 8Last Post: 28th Oct 2007, 01:46
