I'm trying out DVDAuthorGUI and it complains that I need to use ac3fix on one of the .ac3 files. AC3Fix does absolutely nothing at all (literally). Besweet did the same thing. I tried regenerating the original .wav and ran it through both Aften and Super (again) to see if it was either of those. I got .ac3 files, but DAG still complains about them. Weird thing is that DAG doesn't complain about the .ac3 file for the main movie, but it does about the smaller video files's .ac3's and the main movie's audio was processed through Super or Aften (can't remember which), too, so what gives?
log:
***please wait while the titles are multiplexed.
*multiplexing title: 1.....
INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
**ERROR: [???] File unrecogniseable!
INFO: [???] File C:\audiofile.ac3 looks like an AC3 Audio stream.
**ERROR: [???] Unrecogniseable file(s)... exiting.
*multiplexing title: 2.....
Process aborted due to above error
Error code #1
There was an error in one of the video/audio streams. If you are using ac3 audio, make sure that it is without errors by running ac3fix on it. (https://www.videohelp.com/tools?tool=AC3fix_GUI) Please review the log for more detailed information.
What bitrate are you using? Perhaps you are using too high or too low of a bitrate?
Also do the bitrates of the two files match? You can't mix 2.0 256kbps AC-3 with 2.0 192kbps AC-3 etc. unless they are on different ... oh I forget the term now ... VTS "branches" if you know what I mean LOL
Working with Subtitles on a 64-Bit System: XVid, SUPER, & Virtual Dub
By jdanniel in forum SubtitleReplies: 17Last Post: 22nd May 2010, 14:08 -
Aften - Is it really that quick?
By 44echo in forum AudioReplies: 20Last Post: 30th Dec 2009, 23:04 -
Installing Aften
By jsm1963 in forum AudioReplies: 2Last Post: 29th Nov 2007, 19:38 -
How to change the audio from 44100 to 48000 using Aften?
By php111 in forum AudioReplies: 13Last Post: 2nd Oct 2007, 20:58 -
SUPER not working
By Tracyprier in forum Video ConversionReplies: 5Last Post: 26th Jul 2007, 18:36
