I have no problem playing back AVIs that were created on my previous system (Win XP) but all the AVIs I create now (on Vista) only have sound when played back. I usually can tell this also by whether or not the AVI shows a thumbnail in explorer. The ones I create on Vista do not have a thumbnail. Furthermore, when they are launched in Windows Media Player, at bottom left the following appears: "Codecs acquired".
I originally thought it was a codec problem but the fact that its telling me the codecs were acquired makes me think there is nothing missing. Can anyone help out?
You have given us no detail about file formats, players used and what you are using to create AVI's now?
In the meantime, make sure you update DirectX Runtime in any case. This solved several of my issues with Vista. Windows Update has never found this.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2da43d38-db71-4c1b-bc6a-9b665...jnuzY6kg%3d%3d -
thanks,,,i downloaded that and something called Vista Codecs Package....seems to have something to do with the Cineform HD codec that Vegas defaults to....but if i remember correctly, i was having same issue with Premiere....anyway, i'm exporting uncompressed AVI now and its fine.... so maybe it WAS missing a codec that was in the download. thanks again...i'll post back if there's still an issue.
AVIs to DVD - Video fine, no sound ...
By CaptainChaos in forum Authoring (DVD)Replies: 9Last Post: 18th Jun 2010, 19:13 -
File created, but: No Sound & contorted Proportions
By jburkhardt in forum ffmpegX general discussionReplies: 7Last Post: 5th Nov 2008, 15:24 -
wmv files created by Vista shows terrible ghosting under XP
By ambushed19 in forum Newbie / General discussionsReplies: 20Last Post: 12th Sep 2008, 20:49 -
sound but no pic w/Philips 5140 + HDTV avis
By ezu0526 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 22nd Aug 2007, 21:52 -
no sound in vista?
By php111 in forum AudioReplies: 18Last Post: 4th Aug 2007, 00:54
