i understand the premium version allows you to burn dvd's while the free version can't. can someone tell me or at least point me to a walkthrough on how i can do the burn part? i know there's a section called "write" but do i have to use shrink to make the .iso first like i do with the free version,then load the .iso into Fab? please help.
Results 1 to 23 of 23
The best program for DVD burning is called "ImgBurn" and I highly suggest you use that for your DVD (and even CD) burning needs.
The ImgBurn website: http://www.imgburn.com/
There are guides on the ImgBurn website but really it is rather simple to use.
well you can burn DVD's using Decrypter as well as HD Fab Decrypter as well. just thought i'd ask if anyone knew about that. oh well.
Assuming you actually bought HD Fab Decrypter and didn't just download it from a P2P site, I would have to assume that at least one of the following is true.
1) Surely it comes with documentation that explains how to do this.
2) Surely the people who make it can answer this question for you, an honest customer.
3) Perhaps there is even a forum somewhere else dedicated to it that can answer this question.
4) A correctly worded web search might also provide the answer. -
well i checked their site and i don't see anything definite. screenshots of the different features are there but nothing step by step.
Burning a DVD is a delicate thing. There are many factors as to how successful you are and there are several levels of success (i.e., you could burn a DVD that works on some DVD players but not on all DVD players).
I mentioned "ImgBurn" because it is the best program for DVD burning. Period.
ok. well currently i use DVD Decrypter and it does a perfect job 9 times out of 10. But as you can burn with HD Fab Decrypter as well,just thought i would ask. no biggie. thanks again.
I thought Nero was the standard of burning software. How is ImgBurn better (except for the fact it is freeware)? I've gotten used to Nero for years, so I need a good reason to change.
Apparently you don't read the forums here that often.Originally Posted by jimdagys
It's pretty much a proven fact ... for various reasons ... that ImgBurn is the superior DVD burner application.
As for DVD Decrypter ... it is now out-of-date. ImgBurn is by the same programmer and is technically an updated DVD Decrypter in terms of burning BUT he had to drop the DVD ripping part as he was threatened with legal action. So while DVD Decrypter is a good burning application it hasn't been updated in a long while now whereas ImgBurn is constantly being updated for new types of discs and burners and firmware and blah blah blah.
So really at this point ImgBurn should be used for burning and DVD Decrypter only for ripping although there are forms of copy protection that exist now that will give DVD Decrypter fits ... hence the use of other programs for ripping such as DVDFab HD Decrypter etc.
Unlike DVD Decrypter (which can still be very useful mind you) the newer DVDFab HD Decrypter is actively updated to adapt to new forms of copy protection and of course it can do the HD formats as well now.
If your talking about Fab Platinum, It does every thing for you.Originally Posted by Bamahusker
Simply set the source DVD or folder.
Target = your burner
What you want = full disc or main movie etc
Quality = single disc or dual layer
Press start = wait, it will rip, shrink and burn to disc for you! all done.!!
For guides on DVDFab look here:
https://www.videohelp.com/guides?tools=244&&archive=%25 -
The1,it does everything in one step? i thought you had to switch to the write part before you could burn. Anyway,thanks for letting me know.
[quote="Bamahusker"]The1,it does everything in one step? i thought you had to switch to the write part before you could burn. [quote]
Obviously if you set target to a folder then it wont burn.
Check out some guides. -
i checked the guide you sent but it says nothing. like i said ripping is easy but i just didn't know if i was supposed to switch to Write after it rips or what. i get kinda confused as i am autistic so you have to bear with me.
Try the official guide
http://docs.dvdfab.com/" Who needs Google, my wife knows everything" -
looks as if you have to use shrink to shrink the files before you can use the write part. oh well.
Ummm.... since whenOriginally Posted by Bamahusker
DVDFab HD Decrypter is just a ripper....
Ummm.... yeah.... because DVDFab HD Decrypter is just a ripper....Originally Posted by Bamahusker
If you want the compression & burning functions you need to use DVDFab Platinum, a diff. program, the full version of
DVDFab HD Decrypter.
DVDFab HD Decrypter, ripper only = Free
DVDFab Platinum, compress, convert, burn, ect. = Pay -
yeah and the whole time i have been posting about this thread it was in reference to
Platinum. free=no burn Platinum=burn.
You are still missing the point ... burn with ImgBurn and nothing else. Period. End of the story.Originally Posted by Bamahusker
still use Nero 5.5xxx on my old desktop for mostly DVDRs (some CDRs). have yet to get a bad burn due to Nero. gone thru 2 DVD burners, but still use 5.5. lost track how many DVDRs I've burned (1,000?), but still batting 1.000.
have heard versions 6.xxx as well as 7.xxx have issues.
I'm sure Imgburn is a great app as well.
question regarding DVD Fab Decrypter
By Bamahusker in forum DVD RippingReplies: 2Last Post: 3rd Mar 2010, 18:02 -
dvd fab HD Decrypter 6.2.0.5 help
By jyeh74 in forum Newbie / General discussionsReplies: 2Last Post: 11th Jan 2010, 04:55 -
DVD Fab HD Decrypter?
By wulf109 in forum Blu-ray RippingReplies: 20Last Post: 16th Sep 2008, 14:41 -
New to Board DVD Fab HD Decrypter 4 Question
By marine89052 in forum Authoring (DVD)Replies: 3Last Post: 28th Mar 2008, 00:33 -
New to board, DVD fab HD decrypter question......
By marine89052 in forum DVD RippingReplies: 2Last Post: 27th Mar 2008, 21:24
well said FulciLives!
