Results 1 to 14 of 14
    Feb 2002
    Dark Valley,,,Amzon Forest-praries
    I need to know how to cut VCD'S in another way then TMPGenc...........
    If you know any other program or software I should use..please tell me and I will be Grateful...................."stay safe & dont get STUNG"~~~
    Watch out for the Bite........Beacause in life,if you get to far without knowing whats wrong.........you'll Feel the STING
    _-_ ~`*P0!$o|\|ou$ |<0BR@*`~ _-_
  2. Member spidey's Avatar
    Apr 2001
    U.S.A.
    Hey Bud,
    Try using the SOURCE RANGE function prior to encoding. See an example in Sefy's Classical DVD rip guide for Newbie's or in Baldricks DivX to VCD in the new news area.
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
    Feb 2002
    Yo umm listen spidey......I dont understand what your talking about.....Proir resource..Im talking If you know any new softwares or programs....?? "Stay Safe dont get STUNG!!"
  4. Using the source range (and batch encode) makes life MUCH easier. However, if you want to cut an MPEG either bbMPEG or Wobble are the best choices IMHO.
  5. there's alot of programs u can use....
    nero can do it if you get the mpeg patch or media cleaner pro, video pack 5 etc etc....
    Feb 2002
    listen resnullius....do u know any good software(freeware) NOT SHAREWARE programs.......also do you know if you can use Quick Time PRO 5 to cut them beacause that has a "cut/copy movie" feature????
  7. I don't really know any freeware...you can always check with cnet.com...
    as to quick time pro i don't have it i only have the free version sorry... but you can check on apple.com they have fairly good tutorials
  8. maybe if you could tell me why you don't want to use tmpeg i could help you better though
  9. http://www.vcdhelp.com/convert.htm
    sorry for multiple post but here's a nice list on the site...
    Feb 2002
    Ya but i got quick time off morpheus and i got quick time por 5......well i have connections and sources....so0 ahhhh NONE of you helped me
  11. HaCkEr dUDeZ RuLE or something?
  12. TMPGenc freeware ?
    Hi the copy that I got is telling me
    "You can use MPEG-2 function as trial for more 25 days."
    It started out at 30 days. MPEG-1 doesn't show this.
    Version: 2.02.31.119
    Core version 1.80.116
    Anyone else seeing this?
    UpDate:
    Just found this at TMPGenc's site in the FAQ's
    Question - MPEG-2 encoding No.6379
    Juefo ( Mail ) 2002/02/01 (Fri.) 02:06 ( IP:62.104.210.87 ) [ Edit / Delete / Reply with quotation ]
    While trying to encode avi to mpeg-2 i receve the message:
    MPEG-2 trial period has required
    What is the reason for this message and what is to do?
    M0rphis 02/01 (Fri.) 06:57 ( IP:24.205.147.186 ) [ Edit / Delete / Reply with quotation ]
    I too have the exact same problem. If anyone knows why please let me know.
    Seems like I'm not the only one ;-(
  13. because like the pop-up says, they can't distribute a mpeg2 encoder for free so there is a 30 day limit. mpeg1 has no such limitation. If you search the forum you'll find a registry solution to your problem.
