Hello,
I have already converted the avi file to mpeg 2 using tmpegnc and would like to add permenant subtitles before I compile and burn it to dvd. All the guides I have seen so far only show how to add subtitles to avi with xvid codec. Is there a guide that shows how to insert subtitles into mpeg 2 without having to convert back to avi?
cheers
You should have added the permanent subs during the AVI to MPG reencode.
Load the AVI in VirtualDub, add the subtitles using subtitler or textsub filter, frameserve to TMPGEnc.
You can do the same now, by substituting "Load the AVI in VirtualDub" with "Load the mpg in VirtualDubMod" but it requires yet a reencoding pass (and quality loss). But why insist on permanent subs, as Video DVD supports the superior selectable subtitle option, which also won't have you reencode your mpg once again?
/Mats -
Thanks for the advice...I'll try it out and see what happens. To be honest I thought permanent subs were just subtitles that would be able to play on any standalone dvd player.
He means that if you want hard-coded (embedded or "burned in") permanent subs, you'll have to reencode - you'll have to start all over. You can do it using the original AVI, or you can do it (much worse) using your already once encoded MPG.
Much better would be to make your subtitles selectable, like on regular DVDs. -
Originally Posted by nathy85
/Mats -
I get what you mean now. I have just started from the beginning again anyway, as it is wiser as you have said, to sort out the subtitles before encoding the file to MPEG-2.
Thanks for the help and knowledge
MPEG Streamclip / Converted WMV to MPEG-4 but only got the audio? Help me.
By aka_director in forum Video ConversionReplies: 0Last Post: 3rd Oct 2010, 22:24 -
Converted VOB to MPEG-4, Sluggish Playback
By linnium in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jan 2010, 00:04 -
Burn Already converted MPEG Movies To DVD
By killagoob in forum Newbie / General discussionsReplies: 1Last Post: 19th Apr 2008, 20:11 -
Why only one scene visible in a VRO converted to MPEG?
By Stabes in forum Newbie / General discussionsReplies: 3Last Post: 1st Jan 2008, 14:49 -
Having problems getting a MPEG Video Wizard converted/edited DVD to burn
By editup in forum Video ConversionReplies: 18Last Post: 15th Oct 2007, 22:40
