HP drives can either be LITEON or LG rebadged drives.
Results 31 to 41 of 41
This is off the topic, but after installing "ANY DVD" my Nero software reported WRITE ERRORS from both of my new Pioneer drives.
Removed ANY DVD and now burning is normal. -
Depends on what you are doing with Nero Ultra. ImgBurn is a burning app. It will burn data discs and/or DVD's from movie sources (video_ts folders or images(ISO, bin/cue, etc)).Originally Posted by MacPCConsultants
For music discs, you will still need Nero or a free program such as Prassi ONES.
If you are doing anything else with Nero Ultra, then you will want to keep it. Or better yet, get another program designed specifically for whatever you are doing. Nero is a handy all-in-one tool that doesn't do anything really well.Google is your Friend -
This is just a wonderful website and Forum. Awesome. When I refer friends to VideoHelp.com, they agree it's the more information-packed well-designed website on the Net.
Thank you again.
A buddy of mine uses DVDFabHD and said it is great. But what's the diff between DVDFabHD and DVDFab Platinum ? -
Difference is DVDFAB DECRYPTER is FREEWARE & I believe PLATINUM you gotta pay for it.Originally Posted by MacPCConsultants
Originally Posted by budz
No, because there's a 21 day free trial on the DVDFabHD version. It's worth paying for, but where may I find out what PLATINUM adds ? -
DVDFab HD Decrypter is free and will only rip the main movie or all the dvd to your hard drive.
DVDFab Platinum will rip, convert and burn to dvd plus convert to other formats.
http://www.dvdfab.com/docs/ -
Prassi ONES is $25, not freeware.
http://ww1.tx-software.com/boutique_us/liste_produits.cfm?code_lg=lg_us&type=7Want my help? Ask here! (not via PM!)
How to Record using 3 External Burners plus 2 Internal Burners with Speed
By mn072065 in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th May 2011, 19:27 -
Help please! Internal Target Error when burning to DVD
By kylina in forum Authoring (DVD)Replies: 9Last Post: 4th Apr 2010, 14:49 -
dvd recorder internal memory
By mgy999a in forum DVD & Blu-ray RecordersReplies: 4Last Post: 5th Sep 2009, 13:47 -
Do internal/external DVD burners have copy protection built in?
By waldothewonderboy in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jul 2007, 00:01 -
Help with Memorex Internal DVD Burner
By Gdfthr337 in forum DVD & Blu-ray WritersReplies: 2Last Post: 15th May 2007, 13:08
Nero has always been so buggy.
