I have successfully copied DVDs using DVD Shrink and DVD Decrypter.
Now I have installed Bittorrent and have downloaded a movie. It came over as "VLC media file (.avi)" which I assume simply means it is an .AVI file.
I couldn't figure out how to put it on DVD. I eventially determined it needed to be converted to a DVD file. I converted it using WinFF. It now is an "VLC media file (.mpg)". Now I am unable to figure out how to get the Mpeg to a DVD.
What am I doing wrong? What is the process I should be following? Will all file obtained with Bittorrent be .AVI?
Tell me what ever else I need to know to get started.
Thanks.
At the top of each forum is a search field, and also a set of stickies covering most common questions.
To your left are a number of sections, including HOW TO, which is full of guides to most things video related, and Tools, which allows you to look for tools by conversion type (e.g. AVI to DVD)
Finally, there is the User Guides forum, which lists thousands of guides written by members.
If your player can playback Divx/Xvid encoded files then you may not have to convert it at all, just burn it as data. If you do need to convert it I would recommend FAVC or DVD Flick (free) or ConvertXtoDVD (not free), and then burn with Imgburn in Build mode.Read my blog here.
putting dvd files (VOB) from dvd and using in windows live movie maker
By emmawharmby in forum DVD RippingReplies: 8Last Post: 20th Feb 2012, 06:58 -
Putting subtitles on MP4 files?
By Cooperdk in forum SubtitleReplies: 0Last Post: 6th Dec 2010, 06:09 -
Help putting AVI files onto a DVD!?
By rightsidebrain in forum MacReplies: 10Last Post: 24th Mar 2009, 08:40 -
Putting two AVI files on the same DVD
By Mr Sorrow in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 27th Oct 2007, 07:57 -
Putting 2 QT Files w/ 2 seperate .srt files onto a DVD
By whoracle in forum ffmpegX general discussionReplies: 5Last Post: 22nd Jul 2007, 02:57
