I am using Sony Vegas Movie Studio Platinum 8.0 and Sony DVD Architect Studio 4.5, and I can't get any DVD that I burn to play on my DVD players. I have tried using different formats and resolutions, different types of DVDs and different brands and have come up with nothing. I was wondering what format is compatible with the most home DVD players and if there is anything else that I may be doing wrong. Any help in this area would be greatly appreciated. Thank you!
If you are making a DVD to play on most players, then there is only one format and resolution. (With a few exceptions.
) Look to the upper left for 'WHAT IS' DVD.
If you follow those specifications, it should work. You say you have tried different media? Then that should rule media problems out, though some players may be very particular about media brands, some more than others.
The media, the burner and the player all need to be compatible to end up with a DVD that works.
If you use the proper format to create a compliant DVD file, then the problem would be with the media, the player, the burner or the burning program, usually in that order.
Of course, there's a bit more to it.
And welcome to our forums.
Apple's DVD-player doesn't seem to get along with Toast DVD-menus
By HitTheRoad in forum MacReplies: 12Last Post: 11th Aug 2011, 04:24 -
DVD-ROM doesn´t read DVD
By jsilv in forum DVD RippingReplies: 11Last Post: 7th Mar 2010, 07:43 -
My computer doesn't read dvd+rw disk
By jayjayj2 in forum Newbie / General discussionsReplies: 0Last Post: 17th Sep 2008, 13:05 -
AOpen DUW1616/ARR doesn read DVD type disks
By phill in forum Authoring (DVD)Replies: 5Last Post: 9th Sep 2008, 20:46 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59
