Got this error trying to Generate the DVD in FAVC:
"FAVC is unable to process the following files:
[all my files]
Generally this problem occurs when the correct version o f AviSynth is not installed (v2.56a or greater), or the corresponding codec is not installed. Alternative approaches include creating an AviSynth script yourself and opening it in FAVC, or frameserving from VirtualDub to FAVC."
also, the menu preview just shows a broken image.
As long as your version of avisynth is up-to-date and correctly installed, the only other thing I can think of that might cause this problem is the file names themselves. From what I can recall, FAVC doesn't like file names with unicode characters - they must be ANSI (I think that's how you explain it, anyway). For example, all upper and lower case letters are OK, along with numbers, spaces, underscores and hyphens. But stay away from French and Spanish characters and all symbols (ie. é, ç, ű, ß, this sort of thing). I remember once I was converting some of my Pokémon TV caps to DVD using FAVC (for my kids, OK?), and it crapped out because of the "é" in Pokémon.
Anyways, just a thought, but you might want to check it out.
UPDATE: Oops, my bad, in retrospect I don't think it was FAVC that did this to me with the unicode characters, it was another program (don't remember the name since I probably don't use it anymore!). I remember having a similar problem with FAVC, but can't quite remember what caused it. I think one time it might have been that I was trying out avisynth version 2.58 beta and it didn't like that, so I rolled back to 2.57 and it worked OK. -
Switching in mind reading options
Scanning for answers
Answers not forthcoming
Damnit. Looks like you will have to provide useful information yourself.
Start with telling us what your files actually are.
I run FAVC with Avisynth 2.58alpha and still run into this from time to time. It only happens with mkv files, and it is always fixed by demuxing with mkvextract, then re-muxing with mkvmerge using just the video and audio tracks, and dropping all the extraneous garbage that mkv files get filled with.
Of course, because you haven't really given us anything to go on, this information might not be of use to you.Read my blog here.
turns out that i didn't have avisynth installed at all... d'oh!! now i know that sounds like i'm an idiot--but it's not as bad as that because i was told i only needed 2 programs and there was no mention of the third, so i thought avisynth was part of the other program... anyway, thanks for your help!
Favc
By sportflyer in forum Video ConversionReplies: 8Last Post: 19th Feb 2010, 19:20 -
is there a way to override FAVC????
By obadvw in forum Video ConversionReplies: 10Last Post: 25th Jun 2009, 11:53 -
help using FAVC
By eao1 in forum Newbie / General discussionsReplies: 3Last Post: 1st Sep 2008, 18:41 -
FAVC errors
By thai1 in forum Newbie / General discussionsReplies: 6Last Post: 11th Aug 2008, 13:39 -
Retail Layer Break and Imgburn Layer Break..the same?
By Moontrash in forum MediaReplies: 2Last Post: 14th Jun 2007, 12:27
