Hi!
I hope someone can help me out with this!
I have a wmv file. i want to cut out a part in the middle, and i usually do this using virtualdubmod. But virtualdubmod dosen't support wmv, so i used total video converter to convert it into avi (i chose 'decode with internal decoders only').
But when i try to open the avi file (covnerted from wmv) i get this error:
Virtualdub has detected an improber vbr audio encoding... etc.
Wheter i click no or yes i get another error:
"couldnt locate compressor for format hfyu (huffyuv). VD requires a VFW compatible codec to decompress video (...) only direct stream copy is available for this video."
when i click ok, the video doesnt appear.
Does anyone know what i can do to be able to cut out a scene from a wmv? Can i use the prosess i have used so far? What have i done wrong?
Cut wmv with asfbin or movica instead, no video reconverting so no video quality loss. You can also use windows movie maker but the video will be reconverted.
If an editor lets you cut, it sure will let you choose what to cut?
/Mats -
Strange. On my system, WMM has never cut anyting, until I've selected a region, and then told it to cut. I'd be very surprised if I loaded something into WMM and it started cutting stuff on its own accord...
/Mats -
Thanks for you answers
I tried what you said, Baldrick, and it worked liek a charme!!
Thank you so much for helping me out!!!!
cut scene out of .vob using SonyArchitect 5
By stevene in forum Newbie / General discussionsReplies: 2Last Post: 14th Jul 2009, 04:58 -
How to Cut a scene using Avidemux 2.4
By tealmarlin in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2009, 17:08 -
How to Cut out a scene in a movie using convertxtodvd
By tealmarlin in forum Newbie / General discussionsReplies: 1Last Post: 20th May 2009, 08:49 -
How to convert DVD to AVI and cut out a scene?
By superJT in forum Newbie / General discussionsReplies: 13Last Post: 15th Apr 2008, 15:03 -
cut a scene using VirtualDub
By exon in forum EditingReplies: 3Last Post: 19th Jul 2007, 17:05
