Hello,
I have converted all my dvd's to mpeg-4 which played beautifully on my ipod. I purchashed a samsung YH-999GS assuming it played mpeg-4. Silly me. It plays wmv or some obscure file type called asf. So rather that go through the time consuming process of converting to avi I need a shortcut that converts mpeg-4 to wmv. I found Super and tried it but it always gives me an error message. On the basis of this error message I have tried with and without directshow decode but with no luck. Perhaps some setting is wrong. Anyone come accross this before or know of any other free, quick and high quality converters. I'm not asking much am I.
K109
Thanks for the quick reply. I think Super only generates one error message as follows:
Possible causes of encoding failure
An error has occured while encoding.
The most common possible reasons causing error:
If you did not check "DirectShow Decode", you may
try to check it on, as you may have a working ActiveX filter
installed on your PC that could read the codecs of your input file.
Your input source file may not be a valid multimedia clip
due to a damaged header, corrupted/segmented data or truncated
file. Your input file may have unsupported codecs. Verify the
structure and the used codecs of your input file by double clicking
it. The Media Analysis Box opens to display its info, codecs and
other internal data.
There was an interruption of the encoding process due to
Disk space, Slow PC, RAM drainage, CPU overload or a simple
user manual interruption. Try again.
Please discuss all your encoding errors at Super(c)
forum http://www.eRightsoft.com/Supforum.html
I tried checking/unchecking DirectShow Decode. The mp4 file plays normally
and does not seem corrupt. If I double click on it ir plays in Quicktime. I have tried
encoding with services off etc (FSAutostart). I have plenty of free disk space, a fiarly quick
PC and I didn't interrupt. Is there some other test for unsupported codecs ?
Thanks in advance
K109
Convert mpeg-2 to wmv
By king71 in forum Video ConversionReplies: 2Last Post: 25th Oct 2010, 03:26 -
Any software to convert WMV to MPEG? Thanks for helping.
By seymoria in forum Video ConversionReplies: 2Last Post: 18th Apr 2009, 09:18 -
What's the best software to convert Mp4 to WMV/MPEG ?
By billyww in forum Video Streaming DownloadingReplies: 3Last Post: 10th Jan 2009, 17:15 -
Convert MP4 to WMV using SUPER
By bdr13278 in forum Video ConversionReplies: 6Last Post: 21st Aug 2008, 12:19 -
How can I convert WMV to AVI or MPEG?
By betlysmith in forum Video ConversionReplies: 6Last Post: 25th Nov 2007, 01:02
