  1. Member Super Warrior's Avatar
    Whenever i go to play certain videos through windows media player, videos which i think are encoded by variable bitrates, the picture colors are all crazy. To give you an idea, it is like when you open a picture in MSPaint and then click "invert colors".
    I tried clicking update in the WMA menu but it does not do anything. This is windows media player 9 by the way.
    Any suggestions on what i can do to fix this will be much appreciated.
    USA
    Update to a newer version of WMP or give up on it and try some other players. I don't ever use WMP for anything. VLC or others seem to do a much better job. JMO.
  3. Member Super Warrior's Avatar
    Yeah i updated to WMA 11(10 wouldn't install), and 11 seems to work properly.
    Edit: I really, REALLY prefer the look/style on earlier WMAs though.
  4. Mod Neophyte redwudz's Avatar
    USA
    You might look around the net and see if you can use 'skins' for WMP that might change the appearance of the interface.
