hello everyone
please help me in fixing this problem of mine... ii m really stuck with it and i am unable to find any help on google.com..
i m creating a Windows application in vb.net and want to play a video on 6 different locations... so i am adding 6 controls of mswebdvd.... when i am playing all 6 controls together, only first 2 of them get played for a while, then an exception is fired.
i am copy pasting the code as well as the exception:
the code:
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Me.AxMSWebDVD1.Play()
Me.AxMSWebDVD2.Play()
Me.AxMSWebDVD3.Play()
Me.AxMSWebDVD4.Play()
Me.AxMSWebDVD5.Play()
Me.AxMSWebDVD6.Play()
End Sub
the exception:
System.InvalidCastException was unhandled
Message="No such interface supported
Source="MSWebDVD.MSWebDVD.1"
StackTrace:
at MSWEBDVDLib.IMSWebDVD.Play()
at AxMSWEBDVDLib.AxMSWebDVD.Play()
at WindowsApplication1.Form1.Button1_Click(Object sender, EventArgs e) in C:\Documents and Settings\Siraj\Local Settings\Application Data\Temporary Projects\WindowsApplication1\Form1.vb:line 13
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.DebuggableCallba ck(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.UnsafeNativeMethods.DispatchM essageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager. System.Windows.Forms.UnsafeNativeMethods.IMsoCompo nentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.Run MessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.Run MessageLoop(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(ApplicationCo ntext context)
at Microsoft.VisualBasic.ApplicationServices.WindowsF ormsApplicationBase.OnRun()
at Microsoft.VisualBasic.ApplicationServices.WindowsF ormsApplicationBase.DoApplicationModel()
at Microsoft.VisualBasic.ApplicationServices.WindowsF ormsApplicationBase.Run(String[] commandLine)
at WindowsApplication1.My.MyApplication.Main(String[] Args) in 17d14f5c-a337-4978-8281-53493378c1071.vb:line 81
at System.AppDomain.nExecuteAssembly(Assembly assembly, String[] args)
at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
at Microsoft.VisualStudio.HostingProcess.HostProc.Run UsersAssembly()
at System.Threading.ThreadHelper.ThreadStart_Context( Object state)
at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
please help me as to how to overcome iti will be highly grateful to you ppl !
thanks
regards
techie girl
PS: Also attaching the form's pic along with exception's so you can better understand !
Better learn and use C or C++.i'm creating a Windows application in vb.net
C/C++ isn't going to help. ActiveX and COM is COM is COM is COM. VB.NET is a great way to develop apps quickly.
Anyway, to techie_girl, to troubleshoot this, I would start with just one control and verify it plays the DVD correctly. Then add a second and see if both play the DVD. And so on. This will tell you how many of the MSWebDVD controls can be used simultaneously for the same DVD source.
I suspect you are running into a problem with each control trying to access the same DVD at the same time. This could create all kinds of issues with the DVD player having to keep repeating the same thing multiple times.
According to Microsoft (http://msdn2.microsoft.com/en-us/library/ms787412.aspx), the MSWebDVD control doesn't actually control the DVD player, instead it passes requests etc to the DVD Navigator component (exposed as a DirectShow filter). Multiple MSWebDVD controls connected to a single navigator (or multiple navigators to a single DVD source) could very easily upset things - especially if the MSWebDVD-Navigator-DVD scheme is only designed for one instance.
If this is the cause and you wish to display the DVD in multiple windows, you may need to resort to painful methods such as copying the client region of the window (which can be very troublesome when overlays are involved) to other windows. Alternatively, if you can use DirectShow, you could take the DVD output, send it to an infinite tee and then have six video renderers connected to the output side of the tee. You can tell each video renderer to use a window of your choice (such as picture controls on your form). With GraphEdit, you can test the concept without having to program DirectShow graphs etc.John Miller -
thanks for the help !
It runs 2 dvd controls at a time... doesn't show anything in the 3rd one...n fires exception on fourth control onwards...
actually i want to use different controls so as to see different parts of the dvd...
thanks for ur explanation about the reason of its failure... but i didn't get your specified solution to this problem.. can u explain it programmitically ? so i can try it here ?
Please.. i will be really thankful to you...
Regards
Techie Girl
vob2mpg error: Could not get interfaces No such interface supported
By Lowell in forum Newbie / General discussionsReplies: 1Last Post: 3rd Dec 2009, 00:48 -
MeGui -> Unable to locate libsndfile-1.dll and FFTW3.DLL
By whatever911 in forum Video ConversionReplies: 0Last Post: 21st Feb 2009, 15:34 -
How can I fix a "interface not supported" error in avi2dvd?
By Han Solo1 in forum Newbie / General discussionsReplies: 2Last Post: 19th Feb 2009, 15:51 -
Nero 7 installed but no aac.dll or aacenc32.dll?
By AndyD in forum AudioReplies: 5Last Post: 13th Jan 2008, 19:28 -
Is there a list of all supported files supported by svcd2dvd ?
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th Oct 2007, 12:07
