Hello. i just recently bought a tv tuner/capture card (Leadtek DVT2000 H) and using the PVR software bundled with the card. Everything is connected ok, as i am getting audio and video.
When i use the card in TV tuner mode, the audio quality is perfect, and i can tune channels, everything works good etc.
I have connected the capture card to a VCR so i can capture from VHS source, But when switch to CVBS mode the audio quality is horrible. It is not the tape as the audio quality is far better if i play the tape using through the TV.
I have tried other software (amcap) with same problems. Is it just the nature of composite connection that this would hapen?
Composite doesn't contain audio. You should have seperate audio (RCA red/white) cables connected for the audio.
Google is your Friend
Horrible audio synch
By rocks911 in forum Video ConversionReplies: 9Last Post: 13th Jan 2012, 05:50 -
dvdfab quality... im getting horrible results
By ted demen in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2009, 15:18 -
How can I capture VHS Audio with best quality possible?
By faramith in forum AudioReplies: 5Last Post: 13th Feb 2009, 07:09 -
why is my video quality so horrible?
By crazymonk848 in forum Newbie / General discussionsReplies: 10Last Post: 21st Mar 2008, 14:23 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 19:05
