I've been cropping down letterboxed images in TMPG and then applying them to a 640*480 window to view on my standalone DVD player. This works great and I'm happy with the results. My question is does TMPG apply the bitrate to only the cropped portion when encoding or is bitrate still wasted on the black that takes up the rest of the window? I tried encoding at 640 *272 or 352 for different aspects but my DVD player (Panasonic 31K) moves the entire image to the top of the screen instead of centering it. Just to be clear the crop window is only showing the image but the output has the letterboxing.
Make sure you're setting it to 4:3 AR when you encode. Changing resolution has no effect on bitrate. You can try to use a VBR to maybe save some space on movies with few action sequences, but the final file will vary depending on the movie.
What encoding program are you using?
ApacheWraithBlow me for faster replies....... -
Nevermind about the encoding program question, I must've missed you saying TMPGEnc. Under RATE CONTROL MODE choose automatic VBR or 2 Pass VBR and you should be able to set a high BR a minimum BR and and average BR, this should give you a pretty close estimate to what the final size will be, oh BTW set the average to what your BR calculator says should be average for a given number of minutes per cd.
Hope this helps some
Sorry I tried to make it clear, I'm happy with the bitrate I'm using. I'm just trying to find out if the bitrate is applied only to the cropped image (ie. 640 * 272) or to the entire output which is 640*480? I always use CBR because I don't think that VBR works with my DVD player for XVCD?
Thanks, -
Ok that I'm not sure. I'm definately not qualified to answer your question, sorry about the misunderstanding.....
Apache
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
MPEG-2 edit/save, edit/save, edit/save... cycle
By KZemunski in forum Newbie / General discussionsReplies: 8Last Post: 26th Dec 2010, 14:55 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54
