Hey guys i have been having trouble putting my .avi format movies onto my 4.7GB 16x DVD-R's.
My friends has told me that he has Nero, and has been able to drag the movie file into Nero, and burn it to the disc without a problem. He said that Nero does everything for you, converting to AC3 audio, adding chapters, etc.
Is this correct?
Results 1 to 9 of 9
Nero is garbage for encoding movies. Use convertxtodvd or favc if you need a simple solution.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Nero is an "okay" burning program but I would not use it for anything else. If you are looking for a one click style program that offers great quality you should look into the freeware favc. It will convert your avi to ready to burn dvd video_ts folder. When done you can burn that folder with Nero if you really want to... but I would suggest imgburn.
Donadagohvi (Cherokee for "Until we meet again") -
If it weren't for the wave editor, I likely wouldn't even install Nero on my machine. I was an early user, as Nero was the least expensive means of burning a few years back. At least it's not as prone to crashes now as then.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
As a former, non-enlightened, frustrated Nero user, definitely what Freebird said above.
Forums on Nero indicates that various versions of this software work very well for some but not at all for others (for unknown reasons). I used the trial version of Nero 8 and it works like a charm. However, I had Nero 6 previously and it crashed all the times (with the dreaded blue screen!) and I had to uninstall that version.Originally Posted by guitarparth
You will continue to have difficulty until you gain a basic understanding of what the hell it is you are trying to do.
If your and your friend's ability to RTFM are about equal, Nero may very well churn out the level of crap that you are used to.
For those with more brains than God gave a walnut, it is unacceptable.
READ, you lazy dumbass, READ. The answers are all here, just look for them.
Since you are obviously completely clueless, here's a clue. There is a reason there is a SEARCH function. -
Originally Posted by Nelson37
I gotta admit I laughed at that. Nelson you havin a bad day man?Donadagohvi (Cherokee for "Until we meet again") -
That should be fine. We need input like that. Our discussion sometimes gets too serious/boring! I am falling sleep on the keyboard.Originally Posted by freebird73717
Problems burning AVCHD w/Nero & IMGBurn...
By girlcreeture in forum Authoring (Blu-ray)Replies: 7Last Post: 3rd Sep 2011, 11:31 -
problems burning with nero and imgburn-pixlation and long burn
By pokitisme in forum Software PlayingReplies: 5Last Post: 2nd Sep 2009, 03:12 -
Problems Burning Discs with DVDshrink/Nero
By iownju in forum DVD RippingReplies: 5Last Post: 20th Jul 2008, 16:56 -
Will SATA Burners solve problem while burning 2 disks simultaneously?
By nick13 in forum DVD & Blu-ray WritersReplies: 3Last Post: 17th Jan 2008, 05:26 -
burning problems with nero 6
By jjob222 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2007, 16:36
