I have posted the following question in a different thread and got back an answer (I think directed to my question) and suggested I ask for more help!!! so here it is:
My objective is to capture my home made VHS movies (from panasonic camcorder VHS-C) of the kids onto a CD (I do not care for compatibility: XVCD is ok). I would like to know the setting/steps to get my captures at least the same quality as a VHS. I can go up to 2.5MB for rate on my dvd player.
PS. someone suggest using MMC7.5 with MJEG compression... what is that? Does it come with MMC7.5 or I have to download it.
I am using:
AIW 128 PRO AGP card with 32MB
PIII 733MHZ, 128MB
30 GIG hardwrive (7200 RPM)
MMC 7.5 installed and Vdub with wrapper.
Tmpgenc.
Thanx......
Edit the VCD preset, cranck up the bitrate to 2Mbps, and set motion estimation to 100%.
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 12:42 -
capture advice: USB 2.0 video capture adapter?
By j jasper in forum Capturing and VCRReplies: 10Last Post: 26th Feb 2008, 20:18 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 19:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 20:42
