I see alot of people that use CBR (constant bit rate) and VBR (variable bit rate). Here is what I know (or believe to know)![]()
1. CBR has problems with fact action seens
2. VBR takes twice as long b/c of the 2-pass
So what one gives better quality (assuming I'm encoding a long movie)? And if CBR is the case, is it better to encode at a slower or higher bitrate? Are the Bitrate Calculators reliable? I don't want to encode a movie forever and have the fast action scenes be crap!![]()
All-in-All ... what is the best to use for quality purposes?
Thanks,
Extreme
VBR will give better quality, especially as you try to cram more and more video into a given space.
CBR has the convenience of being faster, and necessary for some standards. If you use it, the higher the bitrate the better. Pretty simple really. (For VCD, you cannot exceed 1150Kbps or you will have a nonstandard format).
Of course the bitrate calculators are reliable, we wouldn't use them were they not don't you think?
You have to do CBR, or a form of VBR that allows specification of an average, though (notice this eliminates the CQ modes in TMPGEnc).
ffmpeg rate control
By diprotic in forum Video ConversionReplies: 2Last Post: 15th Oct 2011, 23:35 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 13:21 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 13:53 -
Selectable Output Control - MPAA's new control tactic
By akrako1 in forum Latest Video NewsReplies: 2Last Post: 7th Aug 2008, 22:05 -
Having issues with Clone Mode in Catalyst Control Center...
By Jaxel in forum ComputerReplies: 1Last Post: 25th Feb 2008, 06:08
