    Nov 2007
    Relative novice here. I'm trying to capture Hi-8 home movies to burn to DVD. I’m using the ADS DVD Xpress DX2 hardware encoding capture device. Although I have followed most of the suggestions in the stickies for avoiding dropped frames (defrag, end TSR processes, disable anitivirus, etc.), I still get some dropped frames in the captured video, usually in scenes with substantial amounts of motion. (Strange thing is, there is no loss of audio/video synch. Perhaps it's dropping frames to keep the audio in synch). In any event, The system is a P4 2.54 GHz with 1 GB RAM, an EVGA FX 5500 256 MB video card, integrated audio, and a 60 GB HD (which is 75% free). I’m capturing to MPEG-2 at 640x480, set to the “best quality” setting. (This unit does not allow the user to set the bit rate to a specific number, at least for MPEG-2). I’ve read that a key issue may be to use a separate hard drive to store the captured video. Can I use an external USB connected drive, or even as an alternative a flash memory stick, and still get the benefit that would be associated with using a second internal drive (which I do not have)? Thanks.
  2. Member DB83's Avatar
    Jul 2007
    Methinks No. The external HDD will be too slow(USB) for capture and you will drop even more frames.
    Now 640 * 480 is not DVD quality - that should be 720 * 480 and also more dropped frames if your hardware cannot keep up.
    What you can try is 352 * 240. The is VCD quality but also part of the DVD spec. The picture will not be quite so sharp but that will depend on the size of the viewing screen.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Using a USB capture device to a USB HDD is always going to an issue. You need to go USB to fixed HDD.
    Read my blog here.
  4. Get an eSata drive. Something like this:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822709031
    This isn't an endorsement of that particual product -- I've never used it. But it includes all the hardware you need in case you don't have an eSata port on your PC.
    Oct 2007
    Originally Posted by eclipse95
    ... I'm trying to capture Hi-8 home movies to burn to DVD. I’m using the ADS DVD Xpress DX2 hardware encoding capture device. Although I have followed most of the suggestions in the stickies for avoiding dropped frames (defrag, end TSR processes, disable anitivirus, etc.), I still get some dropped frames in the captured video, usually in scenes with substantial amounts of motion...
    Others have offered appropriate input on the use of USB-hard drive. Your PC specs and the MPG2 capturing hardware look fine for capturing Hi-8 video. I just wonder about the quality of your Hi-8 tapes (?). Old tapes may cause dropped frames regardless of your hardware/software setup. I converted a collection of Hi-8 tapes (some of them 10 years old) to DVDs a few years back and had to live with some degree of frame drops in some of the DVDs).
    Just another factor to consider.
    Nov 2007
    Thanks for the responses. The tapes are in excellent condition; I don't think that's the issue. One thing I've read in searching on this issue is that the integrated audio (as opposed to a separate sound card) may be the cause of the dropped frames. Thoughts? I'd rather try adding a sound card than a separate HD because it's less expense and because I really have no other use for a separate HD (as noted in the original post, the 60 GB HD is only 25% full). I have also read, though, that replacing the integrated audio with a sound card will render inoperable the headphone jack on the front of my Dell PC. A minor annoyance, but a factor. As far as capture resolution is concerned, I could back it down to the lowest horizontal resolution above 400, right? (My understanding is that Hi8 has around 400 lines.)
