Hello there!!!!
Right, here we go.
I've downloaded flip for mac to watch a wmv file in quicktime.... doesn't work.
SO!
I've tried converting it into a dvd in ffmpegx.... doesn't work.
From this the origional file
StarWarsIII.wmv
I end up with 2 files called
StarWarsIII.wmv.ff.mpv
and
StarWarsIII.wmv.ff.ac3
I am using quicktime in high quality to decode in the menu, at 448 for the sound.
Why won't this work??
It's happened with other files in the past not wmv's though. please help
WMVs come in a variety of versions, with and without DRM, so without knowing more about the file's codecs, it remains to be seen if it is at all possible using the regular conversion methods.
If the filesize of the .mpv or .ac3 file is very small, then the conversion may have failed. Check that.
If you let ffmpegX use QuickTime to decode, while QuickTime Player with Flip4Mac doesn't play the source file, then the conversion will likely fail.
What does ffmpegX tell about the source file's video and audio in the Summary tab (left side)? -
VIDEO: WVC1 / 0x31435657,
1920x820
AUDIO: 0x0162, 48000Hz, 5:1, 440
kb/s
(cheers mate) -
Sounds like the OP did end up with the right files, and forgot in ffmpegx,
to check the box in the Options tab that says "author as DVD (Video_TS)"?
perhaps that is what is causing the confusion."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
converting WMV file 408mb to DVD
By jbitakis in forum Authoring (DVD)Replies: 14Last Post: 31st Oct 2008, 08:31 -
Converting DVD to WMV
By DELTAsnake in forum DVD RippingReplies: 1Last Post: 26th Mar 2008, 04:15 -
By Shibblet in forum DVD RippingReplies: 7Last Post: 5th Jan 2008, 06:19 -
Converting Amazon WMV's to DVD
By Hyteckman in forum Video ConversionReplies: 5Last Post: 15th Sep 2007, 14:26 -
converting dvd to wmv
By sliman in forum DVD RippingReplies: 1Last Post: 17th Jun 2007, 04:20
