I added the option for subtitles with ffdshow but now when i downloaded .srt subtitles and added them i got two subtitles overlaping. What should i do? I apply the subs to an .avi file and i play it with Media Player Classic
You have 2 subtitle renderers. Either ffdshow + directvobsub, or ffdshow + MPC itself. Disable subtitle rendering in one of them. Or you have a hard subbed AVI + 1 subtitle renderer active. In that case, disable the latter.
And welcome to VideoHelp! Take your time to read the rules: https://forum.videohelp.com/topic124514.html
You'll find that we don't like threadjacking and double posting at VideoHelp , so I removed your other post on the same subject.
/Mats -
That worked!
Thanks a lot and sorry about the other post
i found that topic about ffdshow and it had to do with my problem so...
System Running Slow when running dvdshrink
By mn072065 in forum ComputerReplies: 7Last Post: 24th Mar 2009, 19:59 -
Same dvds but not all play identical
By aliefjoker in forum Newbie / General discussionsReplies: 1Last Post: 21st Oct 2008, 10:44 -
2 identical wording subtitles on the screen
By workman in forum SubtitleReplies: 4Last Post: 19th Jan 2008, 17:49 -
Removing subtitles, running 1st pass again?
By moviebuff2 in forum Newbie / General discussionsReplies: 1Last Post: 28th Dec 2007, 06:20 -
Why won't identical hard drive work in another identical PC?
By rijir2001 in forum ComputerReplies: 8Last Post: 25th Jun 2007, 09:12
