is it possible to increase the sound from a video? i just downloaded a video clip, however, the sound system is not loud enough, can i increase the sound? what should i do?
Yes. BUT if you want more help you must give us more information. A video can be DVD, AVI, MKV, MP4, MOV, etc and it would also help to know what kind of audio codec like ac3, mp3, wav pcm, etc. You can identify the audio codec in a video file with mediainfo.
okay, these are the video infos...
Complete name : D:\My Music\SPOTAL~1.WMV
Format : Windows Media
File size : 12.1 MiB
PlayTime : 1mn 53s
Bit rate : 896 Kbps
PacketCount : 3966
PacketSize : 3200
HeaderSize : 507
DataSize : 12691250
PlayTime : 1mn 53s
Bit rate : 896 Kbps
PacketCount : 3966
PacketSize : 3200
HeaderSize : 507
DataSize : 12691250
Codec : S-Mpeg 4 v3
Codec/Info : Microsoft MPEG-4 V3
Bit rate : 812 Kbps
Width : 320 pixels
Height : 240 pixels
Display Aspect ratio : 4/3
Resolution : 24 bits
Codec : MPEG-1/2 L3
Codec/Family : MPEG-1
Codec/Info : MPEG-1 or 2 layer 3
Bit rate : 64 Kbps
Channel(s) : 2 channels
Sampling rate : 22 KHz
doc1.doc -
I guess it would be easiest with Windows Movie Maker, see http://www.microsoft.com/windowsxp/using/moviemaker/learnmore/addmusic.mspx (scroll down a bit for the how to increase the volume).
How to increase Video Sound Levels on AVI. Files or Mpeg
By c_a_konopka in forum EditingReplies: 14Last Post: 27th Jun 2012, 21:48 -
How to increase Video Sound Levels on AVI Files or wmv files
By lovebeing in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2010, 09:25 -
Increase sound level of a m4v file
By Neil Crumpen in forum EditingReplies: 1Last Post: 19th Oct 2010, 04:14 -
Can you increase volume of ADPCM sound in movie?
By johnharlin in forum AudioReplies: 3Last Post: 18th Sep 2010, 17:15 -
increase the sound on an iso or dvd
By py52126 in forum AudioReplies: 4Last Post: 15th Aug 2010, 00:37
