  1. Hi,
    I have a large avi file which i want to split into smaller parts but everytime i put it into virtualdub , it is showing vbr error.Then used nandub but the result was the same.Please help.
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Why do you need to split it? Try to avoid splitting/joining if at all possible. Or do you simply want your AVI in smaller chunks, and that's it?
    /Mats
    Use Virtualdubmod and click no that you don't want rewrite the header. Cut. Save.
