    Nov 2007
    Hi,
    I have an Avermedia 4 port capture card, it looks like this:
    http://www.holm-teknik.dk/lx5004/lx5004.jpg
    The problem I am having is port 1 on the card has no video; port 2 and 3 however, work just fine; and port 4 shows video for both port 4 and port 1.
    To explain again:
    port1 = nothing
    port2 = port2
    port3 = port3
    port4 = port4 and port1
    Here is my dmesg | grep bttv:[ 627.686471] bttv: driver version 0.9.16 loaded
    [ 627.686486] bttv: using 8 buffers with 2080k (520 pages) each for capture
    [ 627.686495] bttv: Host bridge needs ETBF enabled.
    [ 627.688839] bttv: Bt8xx card found (0).
    [ 627.689394] bttv0: Bt878 (rev 17) at 0000:02:00.0, irq: 9, latency: 132, mmio: 0xf0200000
    [ 627.689951] bttv0: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
    [ 627.690449] bttv0: enabling ETBF (430FX/VP3 compatibilty)
    [ 627.690499] bttv0: gpio: en=00000000, out=00000000 in=008ff000 [init]
    [ 627.695136] bttv0: using tuner=-1
    [ 627.695158] bttv0: i2c: checking for TDA9875 @ 0xb0... not found
    [ 627.698132] bttv0: i2c: checking for TDA7432 @ 0x8a... not found
    [ 627.700770] bttv0: i2c: checking for TDA9887 @ 0x86... not found
    [ 627.704696] bttv0: registered device video0
    [ 627.705519] bttv0: registered device vbi0
    [ 627.706973] bttv0: registered device radio0
    [ 627.707449] bttv0: PLL: 28636363 => 35468950 .. ok
    [ 627.922151] bttv: Bt8xx card found (1).
    [ 627.922522] bttv1: Bt878 (rev 17) at 0000:02:01.0, irq: 10, latency: 132, mmio: 0xf0202000
    [ 627.923030] bttv1: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
    [ 627.923615] bttv1: enabling ETBF (430FX/VP3 compatibilty)
    [ 627.923661] bttv1: gpio: en=00000000, out=00000000 in=008ffffd [init]
    [ 627.927880] bttv1: using tuner=-1
    [ 627.927901] bttv1: i2c: checking for TDA9875 @ 0xb0... not found
    [ 627.930860] bttv1: i2c: checking for TDA7432 @ 0x8a... not found
    [ 627.933762] bttv1: i2c: checking for TDA9887 @ 0x86... not found
    [ 627.937368] bttv1: registered device video1
    [ 627.938242] bttv1: registered device vbi1
    [ 627.938679] bttv1: PLL: 28636363 => 35468950 .. ok
    [ 628.086047] bttv: Bt8xx card found (2).
    [ 628.086420] bttv2: Bt878 (rev 17) at 0000:02:02.0, irq: 11, latency: 132, mmio: 0xf0204000
    [ 628.086926] bttv2: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
    [ 628.087407] bttv2: enabling ETBF (430FX/VP3 compatibilty)
    [ 628.087456] bttv2: gpio: en=00000000, out=00000000 in=008ffffe [init]
    [ 628.094769] bttv2: using tuner=-1
    [ 628.094788] bttv2: i2c: checking for TDA9875 @ 0xb0... not found
    [ 628.097729] bttv2: i2c: checking for TDA7432 @ 0x8a... not found
    [ 628.100366] bttv2: i2c: checking for TDA9887 @ 0x86... not found
    [ 628.104289] bttv2: registered device video2
    [ 628.105119] bttv2: registered device vbi2
    [ 628.105556] bttv2: PLL: 28636363 => 35468950 .. ok
    [ 628.250142] bttv: Bt8xx card found (3).
    [ 628.250530] bttv3: Bt878 (rev 17) at 0000:02:03.0, irq: 15, latency: 132, mmio: 0xf0206000
    [ 628.251038] bttv3: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
    [ 628.251595] bttv3: enabling ETBF (430FX/VP3 compatibilty)
    [ 628.251642] bttv3: gpio: en=00000000, out=00000000 in=008fffff [init]
    [ 628.253895] bttv3: using tuner=-1
    [ 628.253908] bttv3: i2c: checking for TDA9875 @ 0xb0... not found
    [ 628.256690] bttv3: i2c: checking for TDA7432 @ 0x8a... not found
    [ 628.259340] bttv3: i2c: checking for TDA9887 @ 0x86... not found
    [ 628.262774] bttv3: registered device video3
    [ 628.263177] bttv3: registered device vbi3
    [ 628.263552] bttv3: PLL: 28636363 => 35468950 .. ok
    I have tried many CARDLIST numbers for the bttv drive like 6,13,41,123,124 etc ... but I always have the same problem.
    Any Ideas,
    4dplane
    Nov 2007
    Can a mod please move this post to the Linux thread?
    Thanks,
    4dplane
    Nov 2007
    I have discovered that in my /dev folder I have this:
    lrwxrwxrwx 1 root root 6 2007-11-15 22:02 video -> video3
    crw-rw---- 1 root video 81, 0 2007-11-15 21:37 video0
    crw-rw---- 1 root video 81, 1 2007-11-15 21:37 video1
    crw-rw---- 1 root video 81, 2 2007-11-15 21:37 video2
    crw-rw---- 1 root video 81, 3 2007-11-15 21:37 video3
    I believe this explains my video problems but it does not tell my why the devices are set up like this and why there are only 3 working ports.
    Video0 appears black when I change the symbolic link to:
    video -> video0
    and view capture port 0 and 1.
    Also, if I change the symbolic link to
    video -> video1
    or
    video -> video2
    I get the same kind of problems as in the first post but with different ports.
    It's like there are 3 working capture ports but Linux creates a 4th and links it to one of the working ports.
    AHHHH!!!!!
    4D
    Nov 2007
    Got it!!! - The Linux distribution I was using was kubuntu edgy, but I switch over to ubuntu feisty and the card works perfectly. In the /dev folder there are four devices and no symbolic links to any of them.
    4dplane
