    Mar 2005
    North Star State
    After searching old messages, I'm wondering if there is any new information on making DVD covers from a template? What is available as freeware?
    regards
    beefer
  2. Member terryj's Avatar
    N35°25.24068, W097°34.204
    It's pretty much the same.
    Download the template from where you
    buy your clamshells from ( meritline, shop4tech, etc)
    and then use Photoshop to create the layout and
    then drop the finished .tif or .jpg into the template
    in Illustrator /Corel to output it to a laser printer.
    Or, if you were asking where to get covers,
    I believe the same sites as always ( cdccovers.cc, etc)
    still exist.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    Apr 2005
    Blacksburg, VA USA
    Free? I made an Excel template for a CD-size jewel box that
    works well. You need a utility knife and a straight-edge. It
    works best with cover stock. Let me know, and I'll e-mail
    you a copy.
    Al Bloom
  4. Member classfour's Avatar
    The Heartland, United States
    You may have to work with this - I'd downloaded it from a Google search.
    It did at least give me a feel on generating a blank.[/img]
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
  5. Why go to the bother of measuring and cutting? You can buy pre-made perforated covers. They are not that expensive. I am not good with scissors and by the time you measure and cut, that takes too much time.
    Here is software that comes with a lot of designs and backgrounds for discs and covers. You can even import your own photos and type whatever text you want on the cover.
    Acoustica DVD Label Maker
    http://www.acoustica.com/cd-label-maker/
  6. Member classfour's Avatar
    Wile_E, There are those of us who are waaaaayyyy too cheap to buy the pre-cut ones - including me. Besides, with a high quality rotary cutter; I've been able to get the covers that I make just as I (and my customers) like them. With the right paper (the only premade ones that I actually approved of were the photo glossy ones - pricey at $1 ea) I can produce a cover of such quality that you will not know it was printed on an inkjet.
    Oct 2005
    Here & there
    For a free solution. Search for a dvd template and use gimp or gimpshop , if you are familiar with the photoshop interface.
    I want to believe....
    Oct 2005
    Here & there
    sorry for my reply I didn't realize that it was an apple question!
