Hi all, sorry if this is in the wrong section.
This has so far only happened with one particular movie, "Out of Africa". It has occured in rips from two DVDs of the movie, so I know this isn't caused by a damaged DVD.
When I rip the DVD to ISO, then burn to a blank DVD, I hear pops and clicks in the main movie when playing it in WMP or jetAudio... but NOT when I play it in PowerDVD. The trailers and extra features are not affected, they play fine.
The pop/clicks occur whether I mount the ISO to a virtual drive via Alcohol 120% or if I make a physical copy to a blank DVD disk. This problem has occured with rips using DVDFab or CloneDVD.
Any ideas why WMP and jetAudio are having this problem, but not PowerDVD? I've ripped many other DVDs before and since Out of Africa, with no problems.
Thanks!
I don't know about jetAudio, but WMP isn't much of a player. About all I could suggest is to check the audio with Gspot 2.70 or similar and see what the audio attributes are, then compare them with other DVDs that worked. I would suspect a out of spec audio file.
And it could be something about AC3 5.1 audio and bad conversions by the player software to stereo.
Clicks heard on my OST's CD; actually there or a poor ripping job?
By takearushfan in forum Newbie / General discussionsReplies: 10Last Post: 4th Feb 2012, 00:56 -
clicks and pops in very old VHS tape
By snafubaby in forum Capturing and VCRReplies: 0Last Post: 27th Sep 2009, 03:55 -
virtual dub filters for clicks and pops
By snafubaby in forum AudioReplies: 2Last Post: 11th May 2008, 21:29 -
pops or clicks in wav file
By johnsees in forum AudioReplies: 7Last Post: 30th Jan 2008, 05:08 -
MP3>ac3 pops and clicks
By joesphroth in forum Authoring (DVD)Replies: 0Last Post: 6th May 2007, 15:18
