Hi,
I hope this is the right board to post this to?
I have some .FLV Videos I have downloaded from the net that are a bit fuzzy/blurry that I converted to TS Files so that I could put them on a DVD. I ran the Video files through FixVTS and that worked perfectly taking out the skips and putting things back into sync...but I was wondering if there is any way to clean up the picture and make it clear?
My guess is no since I didnt have a clean picture to begin with?
Thanks Everyone.
LCE
A sharpener filter in virtualdub or avisynth and maybe a deblock filter like http://www.compression.ru/video/deblocking/index_en.html might help a bit but it's usually not worth it. And convert to low resolution DVD 352x240/288 instead of upsizing it to 720x480/576. But Garbage In Garbage Out.
Hi Baldrick,
I have been playing around with the programs you mentioned and a few others but cant figure them out enough to help me.
I also spoke to soon about FixVTS taking out all the skips(Audio) and putting things back into sync it doesn't work on all of them.
Any Ideas on how to smooth out the audio and put it back into sync? I guess for now the quality of the picture can wait although I would like to try and clean it up some as well.
I Appreciate the help
Thank You
LCE
Quick way to merge a Cover picture(preview picture) in a video-file
By arty1 in forum Video ConversionReplies: 0Last Post: 6th Mar 2012, 01:06 -
[Sony Vegas 9] Problem with Picture-in-Picture (Track Motion)
By BramJ in forum EditingReplies: 1Last Post: 27th Jan 2010, 04:52 -
DTS Express PiP (Picture in Picture) / BD Rebuilder question.
By rippn in forum Blu-ray RippingReplies: 4Last Post: 23rd Nov 2009, 16:41 -
tuning picture cleaning off color tubes?
By BroomQueen in forum DVB / IPTVReplies: 8Last Post: 8th Dec 2008, 08:01 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 20:00
