I have several different dvds that I want to take certain scenes from and create a compilation dvd. Is there any freeware that will allow me to do that? I basically just want to copy and paste parts into a whole. I read the sticky that is very similar to my question, but it only addresses trial ware versions.
Should I convert from dvd to mpeg (or some other format?) then back to dvd? What would be the best free software for that? I like how the microsoft moviemaker edits and combines, but I can't get it to do exactly what I want and convert to dvd, just wmv. Help!!!!![]()
Thanks!
dvd shrink in the reauthoring mode, https://www.videohelp.com/guides/how-to-make-a-mixed-dvd-id502#502
Thank you VERY much! I had dvdshrink already, but I didn't realize you could do edit out just parts, I thought you could only do entire chapters. But, it looks like from that tutorial, you still need the TMPGEnc DVD Author, which isn't free. Do I only need that if I want to create menus? What if I do want menus, is there a freeware menu creator?
Thanks again! -
If you want menus you can use guifordvdauthor, dvdstyler, dvdauthorgui but they are not as easy to use as tda.
If I'm not mistaken, you don't have to save or load a project if you make the menus and the output DVD in one go, without exiting the program. You can make a created DVD with menus just fine.
Seeking Rec for convert tool, w/ some editing, need not be freeware
By davbol in forum Video ConversionReplies: 6Last Post: 7th Jan 2011, 16:28 -
MP4 editing > Freeware software that will do it!
By Bodh1 in forum Newbie / General discussionsReplies: 10Last Post: 30th Jun 2010, 02:59 -
Editing Programs.. Hopefully freeware
By sgt_hanky in forum EditingReplies: 2Last Post: 9th Dec 2009, 07:09 -
recommendations for audio editing freeware
By aruwin in forum AudioReplies: 9Last Post: 24th Oct 2008, 06:26 -
Freeware Music Editing Program
By LITEONDVD in forum AudioReplies: 3Last Post: 29th Sep 2007, 01:48
