Been trying to convert some avi's into dvd compliant mpeg 2 files to make dvds with mainconcept mpeg encoder, but everytime so far the output mpg has no audio when i play it in various media players. Choosing layer 2 for audio, and dvd for mpeg type. Opened the mpg in gspot and that says that audio stream is layer 2, so im baffled why theres no sound when played in vlc, nero showtime etc.... any help would be grreatly appreciated![]()
Bert.
Maybe it can't read/decode the audio format in the original files. Try demuxing the audio from one of the original files and converting it to a format recognized by mainconcept mpeg encoder.
Google is your Friend -
Thanks for your reply, the avi files have mp3 audio, can't mainconcept mpeg encoder encode mp3 to layer 2?
Bert. -
VBR MP3 is very difficult for most MPEG encoders to read, so that may be your problem. The 'standard' fix is to extract the MP3 as a WAV audio file using VirtualDub with Full audio processing, then use that with your encoder. Or mux it back in with the video with VD. Or convert it separately to AC3 with ffmpeggui or similar and add it back during authoring.
Thanks for your replies. I used vdub to change the mp3 audio from vbr to cbr (direct streaming the video) but still no sound on output mpg. I guess the mainconcept mpeg encoder has trouble with encoding mp3, so i'll try your suggestions, thanks a lot
Bert.
capturing dvd compliant mpeg-2 with vdub
By wolfdogg in forum Capturing and VCRReplies: 0Last Post: 10th Jan 2012, 20:06 -
need to join 2 dvd compliant mpeg files (having identival characteristics)
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 20th Oct 2008, 11:37 -
Video corruption when trying to convert MPEG-2 to DVD-compliant
By DB83 in forum Video ConversionReplies: 2Last Post: 31st Jan 2008, 20:00 -
Movie freezes after authoring compliant DVD files
By mltwitz in forum Authoring (DVD)Replies: 15Last Post: 21st Dec 2007, 11:29 -
question about VOB compliant files to make DVD
By jimdagys in forum Authoring (DVD)Replies: 3Last Post: 25th Nov 2007, 02:05
